Yaw Sensor Rebuild?
    Results 1 to 3 of 3
      Junior Member PigeonDoubleTake's Avatar
      Oct 2015
      Vermont USA
      Yaw Sensor Rebuild?
      Does anybody rebuild the yaw sensor? Looks like one of the connector pins on mine corroded to the point its barely attached and no longer working. The inside of the unit itself looks like its in good shape. Trying to avoid the full +$600 cost a new one.
      '93 Volvo 240 Wagon (totaled in wreck with 430,000 miles)
      '95 Volvo 850 T5 (gifted to sibling)
      '99 Volvo S80 T6 (death by GM transmission)
      '06 Volvo XC90 2.5
      '04 Volvo V70 R
      Jan 2017
      Cross Country
      Quote Originally Posted by PigeonDoubleTake View Post
      Go to a local electronics repair shop and see if he can fit a new pin. Alternatively, run a wire from that pin out of the case and connect it to the wire in the loom. That’s the cheap fix.
      Oct 2015
      Vermont USA
      Quote Originally Posted by SwissXC90 View Post
      Good idea! I was disappointed that Xemodex seems to do everything but the yaw. But if I can get a electronics shop to do it, it would probably be even cheaper.
      '06 Volvo XC90 2.5
      '04 Volvo V70 R
    Similar Threads
    1. 2010 xc60 body sensor control module yaw sensor location
      By Jhall1983 in forum XC60 (2010 - 2017)
      Last Post: 01-13-2020, 04:07 PM
    2. volvo xc90 yaw rate sensor
      By volvostrader in forum FWD & AWD Parts For Sale
      Last Post: 07-05-2014, 01:41 PM
    3. yaw sensor
      By boostednbagged in forum R Forum (2004-2007)
      Last Post: 05-06-2012, 03:42 PM
    4. Yaw Sensor Replacement
      By Seamus in forum S60 (2001-2010)
      Last Post: 12-27-2011, 08:51 AM
