Engine identification B5244T5 or B5244T?
    Results 1 to 14 of 14
      May 2018
      Takoma Park, MD
      I was hoping someone could shed some light on this.
      I picked up an engine a few months back and have been working on it to drop in my car. It was sold to me as being a T5 motor out of an S60.
      The stamp on the block has it as a B5244T, from what I've been able to find this is usually the engine found in the early X70 cars
      I was always under the impression that a there was a number at the end.
      The engine I have has dual VVT on the intake and exhaust cams.
      Is this a true T5 engine?
      Aug 2010
      Central NJ
      What did the engine come with? What fuel injectors are on there? What spark plugs are on there? Any pictures would help. The B5244T and B5244T5 are 2 very different engines.
      2005 S60 T5 M66 (1 of 72). 4C (for now), Sport Kit, Snabb Short Shifter+Bushings, IPD Track Sways F+R, Bi-Xenon Retrofitted R Headlights - custom fuse box/wiring harness, IPD DP + Oval Tube Exhaust, Forge CBV, Snabb intake pipe, R Brembos F+R, FC04A 17x8+35. coming soon: KW V2, Delrin Subframe Bushings, Do88 Intercooler, Stage 2 Tune. HU-650+Bluetooth Grom+PA300+2xFocal ISS165+ACM-1.300+2x6.5" Dayton Rear Door Subwoofers.
      2005 G55k Family hauler
      2007 Formula SAE Racecar - Custom Tube Frame Chassis, Fox Shocks, Pullrod Suspension, , Wilwood Calipers, Hoosier Slicks, Magnesium 2pc wheels... (full auto-x resto)
      NA1 Supercharged NSX someday.
      Jul 2013
      Georgia
      Quote Originally Posted by hatchbackkid82 View Post
      Are you planning to put this engine in your 1998 - the car in your profile?
      May 2018
      Takoma Park, MD
      Quote Originally Posted by hoonk View Post
      Yep, that's the car it's going in
      May 2018
      Takoma Park, MD
      Quote Originally Posted by broinkrist View Post
      I was told the engine came out of a 07 S60 T5
      There were no fuel injectors or spark plugs in the engine when I picked it up.
      Attached Images Attached Images
      Jul 2013
      Georgia
      What were you going to do with the VVT? Attempt to reuse the head from the 1998?
      Nov 2011
      Do you have the VIN it came out of?
      May 2018
      Takoma Park, MD
      Use a block off plate
      May 2018
      Takoma Park, MD
      Quote Originally Posted by ImportService View Post
      No VIN, just he engine. Would there be a VIN plate anywhere on the engine?
      Nov 2011
      No, no VIN on the engine.
      Was there a front timing belt cover? If so, did it still have the engine # or Serial #?
      May 2018
      Takoma Park, MD
      Didn’t have the timing belt cover either
      B5244T5 is dual vvt (R head) while all other B5244T(X) variants are single exhaust vvt.
      Should have a 05+ manifold.
      Should be setup for ETA not ETM.
      Should have the later thermostat and block casting like a RNC.
      I also see a K24 oil feed line peaking out in the pic. It’s a B5244T5.
      May 2018
      Takoma Park, MD
      Awesome thanks, I really appreciate it
    17. Remove Advertisements
    1. B5244t 80k Miles! $450
      By Parker in forum FWD & AWD Parts For Sale
      Last Post: 03-04-2020, 01:08 PM
    2. Engine swap from B5254t3 to B5244t??? Hear me out before scrolling by.
      By Jakescott3 in forum S40 & V50 (2005-2012)
      Last Post: 06-03-2018, 01:19 PM
    3. Replies: 4
      Last Post: 08-11-2015, 03:44 AM
    4. WTB: B5244T cylinder head.
      By josh913 in forum Want Ads
      Last Post: 01-05-2015, 04:42 AM
    5. Will a b5244t3 (01+) swap in place of a b5244t (00)?
      By heath in forum S70, V70 & V70XC (1998-2000)
      Last Post: 10-25-2010, 01:48 PM
