I have the stock 16” wheels and want to convert those to winter and get a larger rim size for the daily driving. Just wanted to get recommendations.
I am also curious what other stock Volvo wheels would work. I am looking in Facebook and see some s60r with the same bolt pattern. But to make is easier for me, what other Volvo cars would be compatible. I assume the v70?
All 5 bolt Volvo wheels have the same bolt pattern. There are many different offsets. You can use xc90 wheels but the hub centers (at least on 03-15) are larger so you need a hubcentric ring for those.
In addition to being 5 x 108, all the Volvo P3 wheels will be a 63.4 center bore, and most will have a 55 offset. P1 wheels have the same bore, and do/may have a lower offset, but you could likely mount them without issue. P2 (and earlier Volvo wheels) have a larger bore, so you’d need a ring to make up the difference.
My mom’s 2010 has stock 18s and runs 55 series rubber, so you could run all the way up to a 20 with 245/45/r20 tires.
Here's a list of P3 wheels I compiled by browsing each year's sales brochure for each P3 model. I haven't had time to set up hosted photos, but it you google "Volvo+wheel+name" you'll get an image result.
I'm looking to clear out some wheels, have a set of Odysseus in good condition and Zephyrus in very good condition, both are 18". See pics when they were on my cars:
Wish you were closer to MD. I want to turn the stock wheels into the winter set and the car is screaming for bigger rims and wheels.
2010 xc90 3.2 | 2008 xc 70 3.2
Related Threads
3.9M posts
157.6K members
Since 2000
