2011 volvo s60 t6- HORRIBLE GAS MILEAGE
    Results 1 to 20 of 20
      Jun 2019
      Hi,
      Is there anyway for me to increase my gas mileage for my used 2011 Volvo S60 T6 (120k miles)?
      I do a mix of city and highway 50/50, and my average is now 16.2 mpg.
      When I spent a weekend upstate and drove mostly highway, the max I was able to get was 19.
      Is there anyway to improve this? I've already changed spark plugs, and air/cabin filter.
      Also, occasionally my car smells like gas/fuel when the air is on, but the AC is off. No longer smells like gas/fuel if AC is on.
      Is this somehow related?
      My mechanic was not able to find any leak.
      Please help! I'm contemplating selling it due to the these problems.
      Member KCCM's Avatar
      Aug 2011
      Toronto, Canada
      If Iím doing my math correctly you should be getting more like 18 around town and 25 on the highway (my Ď16 V60RD 3.0).
      Any oil consumption or compression issues?
      KECA Kombi - Now '16 V60 T6 AWD R-Design - Just a K&N filter so far, but love the PoleStar tune.
      Junior Member Jewelz1161's Avatar
      Oct 2016
      Sterling Heights, MI
      There is definitely an underlying issue here. My '15 T6 RD (3.0L) gets around 18 city and I've seen up to 28 on the highway. In winter, those go down by about 2 MPG but regardless, your numbers definitely indicate something else is wrong.
      Fuel filter ever been replaced? Or any check engine lights or pending codes?
      Current: 2015 Volvo S60 T6 R-Design Platinum (Polestar Tuned)
      Previous: 2006 S60 T5 M66 (1 of 79 for '06).
      2002 S60 T5 M56
      SwedeSpeed.com
      Plugs-o2 Sensors-PCV-improper tire inflation-use a high quality full synthetic oil and change on a regular basis-leaky injectors.
      Bad o2 sensors can cause a significant drop. Combine that with fouled plugs-dirty/bd PCV-and improper oil grade you can lose a lot of mileage.
    7. #5
      Jan 2019
      North Carolina, USA
      No codes?
      Definitely sounds like a bad O2 sensor, or could be an injector stuck open, or an Evaporative emissions system leak. Depends on where the gas smell is originating from (tailpipe, engine compartment, fuel tank. etc). The smell going away with the AC on is likely because the HVAC system is switching to recirculate and not pulling in the fuel vapors from outside the car. I would do a smoke test on the evap system to check for leaks, and maybe try running some fuel system cleaner through it.
      FWIW, my 6 cylinder T6 averages ~24 mpg in general. I've seen as low as 19 mpg for the 30 min drive home when there is heavy stop and go traffic. I've seen as high as 31 mpg on 60-70 mile trips to the in-laws which is a combination of 70-75 mph highway driving and 55-60 mph country road cruising.
      So there is definitely something wrong with your car. You should never smell gas vapors unless you are filling up the tank.
    8. #6
      Oct 2018
      PNW
      This might be a silly question but have you confirmed that you're actually getting the gas mileage the car is indicating?
      In a previous non-Volvo car the trip computer's reading for mpg was all but useless as it was so inaccurate, I had to use the distance between fill-ups to get a better number.
      2016 V60 T6 AWD R-Design POLESTAR
    9. #7
      Nov 2018
      My 2005 S60 2.5T, front wheel drive, automatic transmission, gets about 22.5 mpg around town, and something like 28 mpg on a trip, at constant highway speed. This is calculated using the odometer, fill up to fill up. I drive conservatively, and rarely accelerate heavily. We live in Texas, and cruising on the highway is typically 65 or 70 mph. I think your car needs some attention in the engine bay.
    10. #8
      I’ve never ever had better than 21mpg on a tankful even with extended highway use. When I did a mix of highway and local driving with longer commutes I’d average 18-20mpg driving briskly. Now that I’m driving almost all short trips I am getting about 15mpg on a tank. These are heavy cars with a lot of drivetrain loss.
      2011 S60 T6 with Polestar tune+TDI-Tuning : KW V3 coilovers : DO88 fmic : Ferrita downpipe : Powerflex "race" torque mount insert
      12.99 at 109mph
    11. #9
      Junior Member Sysyphus61's Avatar
      Dec 2016
      Suburban Philadelphia
      Does depend a lot on the weight of your boots - around town Iím in the high teens most of the time, canít get 20, on the highway I need a good following wind to get to 30 on the highway at legal speeds, and can drop that to the mid twenties by hurrying up a bit, been doing comparatively little highway driving these past few months, and my overall average since I installed my new TFT DIM a few months back is 18.9... thatís running on regular gas.... I get so few opportunities to use the full power of the engine and havenít seen a significant change in consumption since switching from premium, so the 30-50c difference per gallon is an appreciable saving... thereís perhaps a little less ooomph when accelerating from 45 but not sure how much of that is actual performance loss and how much is imagined.
      2009 C70 T5, Celestial Blue 130k
      2011 S60 T6 AWD Caspian Blue
    12. #10
      Member Veefifty T5AWD's Avatar
      Feb 2009
      Lakes Region NH
      I'm averaging 26-27 mpg with mostly highway driving in my T6.
      Logan
      2015 S60 T6 AWD R-Design Polestar
      2008 S40 2.4i - hers
      Former:
      2013 C30 Polestar Limited Edition #87/250 | 2005 V50 T5 AWD | 1995 Yellow 850 T5-R
    13. #11
      Iím getting about 11 in town. C30 t5
    14. #12
      Junior Member Stef1's Avatar
      Mar 2017
      South Shore of Montrťal, QC
      I would thoroughly clean the MAF and throttle body.
      Bright Silver 2015.5 V60, T6 3.0 AWD, P* tune, Simons Touring Catback, Eibach ProKit, various retrofits including adaptive OE xenon
    15. #13
      Who should???
    16. #14
      Mar 2017
      Quote Originally Posted by paradoxicallymodified View Post
      Who should???
      OP, sorry
    17. #15
      Quote Originally Posted by Stef1 View Post
      OP, sorry
      No problem. Mine just eats gas because of my lead foot. Lol.
    18. #16
      Mar 2017
      Get some flip-flops !
    19. #17
      Member
      Dec 2014
      Alexandria, VA
      I know those numbers... Before I sold my C30 I was seeing about 12 mpgs in the city.
      Sent from my HD1907 using Tapatalk
      2015.5 V60
      1987 Chevy El Camino
      1983 Chevy Caprice Classic Wagon
      2008 C30 R Design - SOLD
      1998 V70 T5 Manual - SOLD
      1998 V70 - Sold
      1992 244 - Sold
      1987 245 - Sold
      1983 244 - Sold
    20. #18
      Quote Originally Posted by Seaway View Post
      The k16 driving like a raped ape doesnt help. Lol
    21. #19
      Member
      Dec 2014
      Alexandria, VA
      I just had a stage 3 tune and the associated parts. I found it real hard not to pretend every drive was some sort of time trial. I bet the K16 is fun!
      2015.5 V60
      1998 V70 - Sold
      1992 244 - Sold
      1987 245 - Sold
      1983 244 - Sold
    22. #20
      Yeah-27-28 psi under your foot is addictive
    23. Remove Advertisements
    Similar Threads
    1. Horrible gas mileage-V90 T6CC
      By Amazon in forum S90 & V90, V90CC (SPA: 2017 - )
      Last Post: 06-08-2018, 09:46 AM
    2. 1998 V70 XC AWD p0131 and p0172b Horrible Gas Mileage
      By Arathi in forum S70, V70 & V70XC (1998-2000)
      Last Post: 12-16-2013, 10:23 AM
    3. worth $350? 240 80k mi, white smoke @ acceleration, horrible gas mileage
      By bdimag in forum 240, 242, 244 & 245 (1974-1993)
      Last Post: 05-25-2008, 05:36 PM
    4. Horrible, horrible noise from my front wheel.
      By davidklaw in forum S40 & V50 (2005-2012)
      Last Post: 04-27-2006, 10:49 PM
    5. Gas tank, Gas Gauge and Mileage
      By rs4-380 in forum 240, 242, 244 & 245 (1974-1993)
      Last Post: 01-20-2006, 11:37 PM
