Difference between Memory 1/2 and Driver Profile?
    Results 1 to 13 of 13
      Feb 2020
      I have set up a driver profile for me, matched to my fob. My question is, what is the difference between that, and the memory setup (on the door), or why even have those memory settings? Seems redundant to me, but I'm sure I'm missing something.
      Is it there to be like older cars, and don't want to set up a driver profile, but want to have your seat and mirrors set in memory?
      Junior Member stocis's Avatar
      Oct 2019
      Cyprus
      not sure if I understood the question but the memory profile is there for different drivers to have their own settings without the need to do so every time.
      Current: 2020 Volvo XC60 R-Design, 2018 Volvo XC40 R-Design
      Previous: 2009 Volvo C70, 2006 Volvo S60, 2003 Saab 9-5, 1999 Mitsubishi FTO, 1998 Land Rover Freelander, 1995 Suzuki Swift Sedan
      Feb 2020
      Quote Originally Posted by stocis View Post
      Right, but the driver profile does that same thing, yes? In fact, I can't even set the memory buttons to do anything, probably because I have a driver profile set up.
      SwedeSpeed.com
      Oct 2019
      Cyprus
      maybe you're referring to the seat profile? M 1 2 ? if you are.. then to save you need to first press M and then the number of your choice.
    7. #5
      Feb 2020
      Right, I get that, that's like every other car made in the last 20-30 years, etc. My question is, why would you even need that, if your driver profile remembers those same exact things, and more?
      It seems like the driver profile makes the memory positions unnecessary, yes?
    8. #6
      Oct 2019
      Cyprus
      no, because if your wife or whoever else drives the car can have his/her profile with his/her preferences saved as well as 2 seat memory.
    9. #7
      Member Seti's Avatar
      Oct 2016
      Afrique du Sud
      Maybe you're right, but I use all memory settings to myself
      E.g., memory 1 is my regular daily driving setting and occasionally for fast driving
      Memory 2, is when I drive long distances and want a more relaxed driving setting. It's where the seat is set as far from the pedals as possible so my legs can be rested or stretched with ease.
      Memory 3 is when my tummy is too full or am wearing thick clothing causing the seatbelt to tighten around my belly a little. So, this setting allows me to be relaxed by reclining and moving my seat to create that extra space.
      If steering column was automatic, I'd play more with the steering than seat settings.
      Currently, my steering position is fixed regardless of my seat positioning because I hate adjusting it manually all the time.
      Driver profile wouldn't help me in the above scenarios. And yes, I'm the only driver of my car and the garage tends to mess with my settings every time I sent it for annual service maintenance.
      Sent from my SM-G950F using Tapatalk
      T8 Inscription - With almost all bells and whistles, bar leather on dash and upper fascia - Regretting not having them
    10. #8
      Member BigBang's Avatar
      Mar 2018
      World
      Quote Originally Posted by Baba View Post
      It's that simple, just read the Owner's Manual (online, print or in-car)
      https://www.volvocars.com/en-th/supp...river-profiles
      https://www.volvocars.com/en-th/supp...ead-up-display
      2018 XC60 T5 R-Design
    11. #9
      Mar 2018
      World
      Quote Originally Posted by Seti View Post
      Memory 1, Memory 2, Memory 3 ?????? Your car has three memories
    12. #10
      Oct 2016
      Afrique du Sud
      Yes, for the driver and passenger sides. 3 settings per door. I know this is XC60 forum, but I'm XC90 and commented on seat settings.
      Apologies if I mistakenly created the impression I was referring to XC60
    13. #11
      Mar 2018
      World
      Thanks for the explanation
    14. #12
      Junior Member OlRedHair's Avatar
      Sep 2003
      Florida
      My 850 has three settings, and my XC40 has two settings. And they each are set in a different way. In the 850 you push M and the number simultaneously. In the XC 40 you push M and then in a second press one or two
      Nora in Florida
      Nora in Florida
    15. #13
      Member
      Dec 2017
      PNW
      When driver profile is messed up for whatever reason, I use the 1,2, buttons to get my seat in right position. :lol:
      Rolling, Fusion Red - 2018 XC60 - T8
      Running to retire, 2000 V70XC 237240 miles [2020-07]
    16. Remove Advertisements
    Similar Threads
    1. Replies: 3
      Last Post: 12-02-2019, 09:05 PM
    2. Replies: 19
      Last Post: 08-10-2018, 10:57 AM
    3. Driver Profile Questions: Seat Memory and Key Fob Linking
      By BrianV in forum XC90 (SPA: 2016 - )
      Last Post: 12-22-2016, 08:14 PM
    4. Pairing Key to Seat Memory and Driver Profile?
      By pritesh0381 in forum XC90 (SPA: 2016 - )
      Last Post: 12-03-2015, 10:22 AM
    5. Memory driver's seat loosing its memory
      By retired12 in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 04-18-2005, 08:31 AM
