Cam seals leaking? Looking for firm way to diagnose
    Results 1 to 4 of 4
      Apr 2014
      I am fairly sure that the car has developed the ol cam seal leak. But I wanted to ask around to see if there are other ideas or the best way to diagnose it.
      Noticed a new oil drip on the driveway under the car recently. Right side, in the middle of the wheel-well, and outside of the skid plate. Looked under and saw some drips on the plastic shield over the axle, coming from above. Checked the banjo for the turbo oil feed and it was all dry. I can seem some oil on the timing cover on the exhaust side.
      I pulled the plastic covers over the cam gears, intake looks fine, the back of the exhaust cam looks like it might have been a little damp, very slightly. More shiny than anything. But looking down inside the cover I don't notice anything obvious below the cam gears for leaking.
      I did just replace the diaphragm for the PCV, had the tear and the howl. Car wasn't driven on torn PCV for very long as far as I know. I parked it once the diagnosis was confirmed torn PCV diaphragm. But maybe it was possible that it was long enough to hurt the cam seals?
      Global Moderator tmtalpey's Avatar
      Jun 2004
      Eastern MA
      You're describing the cam seal leak, with the location of those drips. The best way to confirm is to pull the top-front cover, over the cam pulleys, from where you can shine a light behind them and see the telltales.
      Yes, a PCV issue will cause this, and replacing the PCV does not undo the problem in many cases.
      2005 V50 T5 AWD 6MT w/Heico tune, Heico exhaust, Bell intercooler, IPD TCV, Viva Forge CBV, Elevate rear swaybar and torque mount, Snabb shift kit, etc.
      2016 XC60 T6 AWD
      1956 PV444 complete, running
      1956 PV444 very original, very rough
      The ol PCV wrecked another component trick. Im telling you man-these Volvos need their oil changed regularly and I change the flame trap ever 3 years regardless of mileage. Had the plastic cover pop and blow oil all over the damn place. Never again. Ounce of prevention is worth a pound of cure.
    5. #4
      Member
      Jan 2011
      Arizona
      There is an outer and inner timing cover. The inner cover sits behind the timing components. Cam seal leaks will leak down the engine behind that inner timing cover leaving it clean of oil. I learned this the hard way.
      2007 S40 T5
    6. Remove Advertisements
    Similar Threads
    1. Timing belt, cam seals, and crank seals?
      By Kreger607 in forum General Volvo Discussions
      Last Post: 01-27-2017, 08:22 AM
    2. Is there an easy way to diagnose bad engine mounts?
      By 377Z in forum R Forum (2004-2007)
      Last Post: 11-05-2014, 11:40 AM
    3. Leaking Cam Seals
      By marshcat in forum S40 & V50 (2005-2012)
      Last Post: 03-29-2014, 08:50 PM
    4. Gen 1 T-belt components (mechanical), cam seals, etc.
      By AthruC in forum FWD & AWD Parts For Sale
      Last Post: 03-03-2010, 07:35 PM
    5. Replies: 2
      Last Post: 02-16-2008, 10:18 PM
