Propshaft removal
    Results 1 to 3 of 3
      May 2015
      Southern California
      Propshaft removal
      I need advice on how to remove the drive or prop shaft and wondering how to turn the shaft to get to all six bolts. I tried neutral gear but still not able to turn the shaft. How much force is needed or what is the trick? The rear wheel are in the air and the front on ramps.
      Jul 2013
      Georgia
      Quote Originally Posted by 2010S80 View Post
      All 4 tires have to spin free - or at least 1 on each end of the car -
      Turning the driveshaft spins the transfer case - and there is not a clutch in it to allow the rear diff to spin without the front diff spinning. You could just have 1 front and 1 rear wheel off the ground and spin the driveshaft (in neutral)
      May 2015
      Southern California
      Thanks.
    Similar Threads
    1. Replies: 20
      Last Post: 05-19-2020, 12:10 AM
    2. XC90 propshaft removal
      By KJ4x4 in forum XC90 (2003 - 2014)
      Last Post: 11-28-2013, 03:55 AM
    3. Putting speakers on rear hatch, ceiling removal, floor removal, panel removal?
      By sicilianhotdog in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 07-17-2011, 08:55 PM
    4. AWD Propshaft maintenance
      By S60 D5 in forum S70, V70 & V70XC (1998-2000)
      Last Post: 02-25-2011, 02:17 PM
    5. where can i find propshaft middle bushing that holds the bearing 2001 xc
      By mikes60 in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 11-25-2009, 10:56 AM
