16T turbo upgrade 2.5t
    Results 1 to 9 of 9
      Question 16T turbo upgrade 2.5t
      Hello everyone, my turbo recently blew up on my 2.5t and I heard a 16t is the optimal upgrade for the 2.5t. My question is, can I hook up a 16t from a 2.3t without any modifications? I heard about differently angeled flanges and I want to make sure that I will not run into any issues regarding fitment and connections.
      Member Exocet's Avatar
      Nov 2017
      Southern Tier NY
      2003 and later 16Ts have the same oil and cooling connections as the 14Ts.
      Sent from my SM-G950U using Tapatalk
      2007 Volvo V70 2.5T - Mine
      2008 Nissan Titan SE 4x4, Crew Cab, Long Bed - Also Mine
      2012 Toyota Camry LE, 2.4 - Wife's
      2003 Mazda Protege5, 2.0 - Daughter #1
      2010 Mazda 6 Grand Touring, 2.5 - Daughter #2
      Junior Member platinum855's Avatar
      Jul 2015
      Chicago
      don't forget to swap out the OTE pipe also. there's one in the classifieds right now (not mine)
      BLACK PEARL- 06 V70 2.5T: Snabb intake, OBX/Vibrant/TME exhaust, lowered on Vogtland/Sachs, 305mm front brakes, Tethys
      SwedeSpeed.com
      Nov 2017
      Southern Tier NY
      The coupler is also a little different.
    7. #5
      Junior Member JonE1976's Avatar
      Oct 2016
      Garner, NC
      I'm the current owner of that OTE and a set of blue injectors. PM me with an offer. You can run with your oranges but if they're sloppy you could run into engine damaging trouble. Swapping to blues gives you piece of mind but a tune would be mandatory to use the blues. If I were going to use oranges I would get mine cleaned and flow tested before putting on the turbo. Any low flow numbers and I would replace the injector. You're running with little to no reserve duty cycle on the oranges.
      Without a tune you'll see faster ramp up to power and power holding into the upper RPM bands but the computer is going to fight to keep you at stock levels. To really make use of the turbo a tune is a must. The faster ramp up is where the danger lurks. Sloppy oranges plus a fast ramp up that the stock tune can't handle will threaten the engine.
      Make sure the boost regulator and turbo control valve are in tip top condition. I would run a stock pressure spring in the TCV. I would also replace all of the vacuum lines and replace the turbo boost pressure valve with a new volvo branded unit. Off brand solenoids are not worth the risk and old hardware is inviting disaster. Stay away from ebay "new" turbos as well. Total junk.
      Installing with oranges and no tune would run between 650 and 850.00 if you can get a cheap 16t and rebuild it. add 600 to 1000 for a tune.
      2005 S60 2.5T AWD
      2014 XC60 T6 AWD
      Didn't learn from the 2005s repair bills and brought home a second. I'm a glutton for punishment I guess
    8. #6
      Senior Member ScottishBrick's Avatar
      Dec 2014
      Connecticut
      Exhaust downpipe flange is the same. As covered above the water and oil lines are the same for all Mitsubishi 2003+ turbos (14t and 16t), the intake from the maf to the turbo is the same. You will need a different OTE pipe because of the neck on the 16t being shorter than the 14t. Coupler should be the same but earlier turbos have a very nice multi layer silicon coupler that can e used. Tune and fueling upgrades are recommended to maximized however it is safe to run it as is, me7 is load demand engine management and will only make the boost/load it requires. The benefit with stock maps is that the 16t is so much of a larger turbo (in comparison, they’re still pretty small as turbos go) that it’s incredibly efficient at the lower boost levels an XC runs so you will be making a lot of flow and much much less heat compared to the 14t.
      2003 V70 T5 - Mystic/Graphite - M56LK - 211k - K24/Greens/Do88/Quaife/SMF/P2R Clutch/DW300C/H&R/Bilstein TC/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 305k - Daily/Work Wagon
      1999 V70 T5 - Nautic/R Graphite & Alcantara - M56H - 177k - Rescued
      1999 V70 T5 - Emerald/Graphite - M56H - 119k - Garage Queen
      2000 V70 T5 - Mystic/Graphite - AW42 - 246k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 218k - Sisters
    9. #7
      Jul 2015
      Chicago
      for those that have done the swap, two questions:
      -how hard is it to remove solely from the top?
      -are there any gaskets or washers that automatically need to be replaced with install?
      Thanks
    10. #8
      Dec 2014
      Connecticut
      Quote Originally Posted by platinum855 View Post
      Thanks
      Easy.
      Manifold to turbo gasket, turbo to downpipe gasket. 6x 11994 washers (2 each banjo bolt), turbo return drain upper seal and lower o ring.
      You’ll need an earlier (and larger) over the engine charge pipe but that’s easily sourced and bolts on.
    11. #9
      Jul 2015
      Chicago
      Quote Originally Posted by ScottishBrick View Post
      Easy.
      thanks buddy
    12. Remove Advertisements
    Similar Threads
    1. Injectors sale or trade for a used 15g turbo or 16t turbo chra or whole turbo
      By Platinum_brick in forum FWD & AWD Parts For Sale
      Last Post: 08-02-2019, 07:34 AM
    2. 16t turbo upgrade for 2.5t lp engine from ARD
      By Valeyard in forum S80 (1998-2006)
      Last Post: 02-02-2014, 09:27 PM
    3. best ecu tune for 2.5t lpt engine with 16t turbo upgrade
      By Valeyard in forum S60 (2001-2010)
      Last Post: 02-02-2014, 11:02 AM
    4. 16t or 18t upgrade on 2.5T engine?
      By Stefan1235 in forum S60 (2001-2010)
      Last Post: 02-25-2012, 11:16 AM
    5. Replies: 259
      Last Post: 03-12-2011, 02:42 PM
