M66 Trans oil recommendations
    Results 1 to 16 of 16
      Junior Member black944 turbo's Avatar
      Apr 2018
      Charlotte
      I changed my transmission gear oil about 1.5 years ago with Redline MT90 and noticed that it is getting a bit notchy with this fluid ( I have read others that have said the same thing). I can buy Redline MTL locally, but would love some recommendations on what works best. I am not a fan of the OE fluid because it doesn't seem to minimize the sound of my SMF that is installed, redline has seemed to help a bit with this. In the same breath, I am ok switching back if it is the best for shift quality.
      2005 V70R M66, Titanium-Gobi
      1986 944 Turbo, Black-Tan
      Past; 940t wagon, 940, 960 wagon, 240 wagon and several others in the family.
      Junior Member LukeFlynn's Avatar
      Feb 2019
      Knoxville, TN
      Heard good things of Amsoil severe gear for reducing chatter.
      I tried liqui moly 75-90 gl4 and it sucked, notchiest shifting Iíve ever felt on an m66.
      Iím probably going to try out the severe gear soon, but itís expensive.
      '04 XC70 | Silver Metallic/Nordkap 220K | Shimmed B5254T2 | K24 | M66 w/ SPEC single mass | EST Sport catback | Elevate sways | BC Coilovers | Hilton Stage 3 Tune
      '13 C30 T5M | Black Stone/Black | 135K | Stock
      Past - 09 S40 2.4I, 04 S60R M66
      Instagram - @boostedxc
      Jul 2009
      Iím using Redline MTL and Iím very happy with it. I recommend it.
      SwedeSpeed.com
      Junior Member Rodtheviking's Avatar
      Jun 2019
      Vancouver, WA
      Redline or Mobil 1 is what I have use over the last few years. Audi's, Land Rover, 4Runner etc.
    7. #5
      Member Red_Devil's Avatar
      Jun 2010
      Mass
      I tried a few oem for trans and amsoil for ag and oem for the rest of the car drivetrain. Motul or amsoil for engine oil and oem filter.
      2018 Leadfoot Ford Raptor semi built 600hp, 2020 Audi RS3.
      05 S60R MT, Stock block 578AWHP, 12.2 1/4 mile at 124 mph. Built 804 AWHP. Built engine, Cnc ported head, Front & Rear LSD, Ported Gen 2 T4 GTX3584RS hybrid, Turbosmart 45mm WG, Tial QR Bov, Enem Y21 Cams, Radium Surge tank, 1700cc Id's, Triple Walbro 485's, PM3, Devils Own meth injection, speed density converted mafless setup, Bell FMIC, Snabb air box, Poly, Milletech intake manifold, IP plasma coils, IP Plasma lift. Snabb shifter. TTV Twin Clutch. GB Forgestar F-14's, Enkei RSF5, KW V2'S, Ur Braces, Vr sways, IPD toe bars. Built to the hill.
    8. #6
      Member Body Massage's Avatar
      Aug 2008
      Bellingham, MA
      I went with Amsoil SG. It didn't really impact the SMF chatter.
      Additionally, when it's cold, the transmission is hard to get into 2nd. It's completely fine once everything is warmed up. It did not have those issues prior to the SG
      2005 V70R
      2010 C30 R-Design
    9. #7
      Apr 2018
      Charlotte
      Thanks everyone, I am mainly trying to accomplish a smoother shift again. It sounds like OE may be my best bet. I was considering MTL and amsoil sg, but it sounds like they may have similar issues to the mt90.
      It's funny, I have run mt90 in the 944 for years and it shifts great with the exception of very cold weather.
    10. #8
      Apr 2007
      Nashville
      I've had Redline in mine for the past 35k, no complaints!
      04 V70R Flash Green/Atacama6MT
    11. #9
      Feb 2014
      New Orleans, LA
      Another endorsement for Redline.
    12. #10
      Junior Member lolvos60R's Avatar
      Jun 2015
      Plainfield, CT
      If itís a gl5 fluid itís not to good for the brass syncros. Try sticking to a gl4 fluid.
      Iíve been using this with no issues.
      Sent from my iPhone XR using Tapatalk
      05 sr sapphire/nordkap, three pedal arrangement -Contrast Works stg1 18psi w/ 4c map switching -Custom 3" intake pipe w/ swedesource drop-in filter -stock air box -dw 300c fuel pump welded A.G. Bob villa mod PPS: Poly front control arm bushings -poly torque mount-poly subframe inserts Powerflex: race #12/street #5,8,13 Ipd toe bars BC coil overs EST D.P. catted w/ Viva performance exhaust w/o resonator Goodyear eagle f1 asymmetric 2 235/40-18 and of course PEGS!!!
    13. #11
      Jan 2009
      Redline MTL and all is well for me.
    14. #12
      Jul 2012
      Davenport, CA
      Quote Originally Posted by lolvos60R View Post
      yes! GL4 only - whats wrong with OE?
      04 V70R M66
    15. #13
      Jul 2013
      Albany
      The Amsoil Severe Gear 75w-90 states that it is ok as a sub for GL4 and there is a pdf floating around on the internet about their GL5 fluid passing some threshold of safety for brass synchros.
      That being said, I've also read that the SG fluid is probably overkill for our gearboxes and have stuck with the GL4 amsoil fluid cited above.
      Some people do swear by the SG though. I ran the SG for a short time and I do agree that that GL4 fluid seems to feel better than SG as well as better than OEM. Never have an issue putting it into any gear really, where I did have some issue putting into first with OEM fluid.
      05 V70R BSM, 6MT
    16. #14
      Apr 2018
      Charlotte
      I went ahead and put the MTL in it and it seems a good bit better than the MT90. I have only driven it about 15 miles, again already a large improvement in going into gear. I went this route for two reasons. 1. There is a small father son speed shop near by that carries it. 2. I have had great results in my other car with redline gear oil. Time will tell.
    17. #15
      Member MN-TURBOR's Avatar
      Jun 2011
      Twin Cities, MN
      same stuff ive used for the last 4 drain and fills. its good stuff!
      2007 S60R - Ti Grey/Atacama M66 - Stage II Shark Tune - 8EightFab downpipe - Custom Magnaflow Exhaust - SNABB FMIC/Intake Pipe - TWM Short Shifter - Forge CBV - UR Front Brace/Rear Brace - IPD 28mm Rear Sway Bar - BC Racing Coilovers
      2007 XC90 V8 Sport - Electric Silver - Muffler/Resonator Delete
      2007 XC70 - Ice White - Stage I Shark Tune - Muffler Delete
    18. #16
      Moderator MvI_S60R's Avatar
      Nov 2013
      Stow, OH
      I used 1 QT Severe Gear and 1 QT of Redline Lightweight Shockproof oil and it seemed to work for like a year but itís gotten notchy and chatter is louder but it has been quiet before. The shockproof stuff is blue and sorta slippery. Honestly not a fan, itís nearly crunchy when itís hot now it degraded like milk and I shift like a grandpa.
      I am switching to 2QTs of Amsoil Manual Gear oil and Im also going to add in a tube of concentrated moly to protect it some and quiet it down. Iíve talked to a bunch of other people running transverse trannyís with SMFs and they seem to like it. Ill flush it twice with my new mix and report back.
      This is the moly I got https://www.amazon.com/dp/B00CPL8UPY...p_mob_ap_share
      // '06 S60R M66 | Magic Blue | 19" FC04A's | KW V2 | Stage 2.25 | Literally all the mods | MY BUILD THREAD
      /// '20 V90 R-design | Bursting Blue | Advanced | 4C Air
    19. Remove Advertisements
    Similar Threads
    1. Can M66 AWD Trans be used for M66 FWD? Thoughts
      By Oceans60R in forum R Forum (2004-2007)
      Last Post: 02-05-2020, 05:49 PM
    2. Replies: 3
      Last Post: 10-01-2019, 08:28 PM
    3. Replies: 12
      Last Post: 04-29-2019, 10:16 AM
    4. oil cooler and trans oil filter add mod
      By dougy in forum XC90 (2003 - 2014)
      Last Post: 08-31-2018, 09:38 PM
    5. S70 auto trans vs. S60R M66 trans
      By Turbo driver in forum S70, V70 & V70XC (1998-2000)
      Last Post: 12-13-2013, 05:46 PM
