Finished the clutch job but no power to ignition
    Results 1 to 5 of 5
      Dec 2015
      SLC Utah
      The 850R clutch and SMF install is complete on the S60. I pulled the entire engine and tranny for this job. Was very nervous and excited to fire her up as this was my first clutch job. Turn the key and nothing......Battery fully charged. No Voltage up front. Checked ignition fuse #25 and its good. This is my second time pulling and installing a T5 engine so i feel fairly confident ??? I reconnected all electrical components properly. When bleeding the clutch i didn't connect a drain hose and had some fluid spurting around, but i doubt it was enough fluid to short anything. Hoping someone can suggest something i may have missed.
      01 S60 T5M Black, middle sons
      00 S70 GLT Black, youngest sons
      00 S70 GLT5 SE Moondisaster, T5 Swap
      00 V70R Black, First P80 Wagon
      01 E46 325 XI Touring Silver, Wifes, totalled, bought back, repaired
      Senior Member ScottishBrick's Avatar
      Dec 2014
      Connecticut
      Recheck the battery clamps. That main hot you tested comes all the way direct from the battery it shouldn’t be key switched.
      2003 V70 T5 - Mystic/Graphite - M56LK - 209k - K24/Greens/Do88/Quaife/SMF/P2R Clutch/DW300C/H&R/Bilstein TC/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 303k - Daily/Work Wagon
      1999 V70 T5 - Nautic/R Graphite & Alcantara - M56H - 177k - Rescued
      1999 V70 T5 - Emerald/Graphite - M56H - 119k - Garage Queen
      2000 V70 T5 - Mystic/Graphite - AW42 - 245k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 218k - Sisters
      Junior Member LukeFlynn's Avatar
      Feb 2019
      Knoxville, TN
      There should also be two big hots there, I only see one but it might be the picture. One runs from the battery, the other runs down to the starter, they are bolted directly on top of each other
      '04 XC70 | Silver Metallic/Nordkap 220K | Shimmed B5254T2 | K24 | M66 w/ SPEC single mass | IPD catback | Elevate sways | BC Coilovers | Hilton Stage 3 Tune
      '13 C30 T5M | Black Stone/Black | 135K | Stock
      Past - 09 S40 2.4I, 04 S60R M66
      Instagram - @boostedxc
      SwedeSpeed.com
      Dec 2015
      SLC Utah
      Quote Originally Posted by LukeFlynn View Post
      Thank you kind sir, that was indeed it. All is well with the swap. Pedal grabs instantly where before it was almost all the way out before the clutch grabbed. I popped an intercooler hose during test drive. I'm getting a fault in Vida for "Throttle position sensor" Guessing ETM is getting tired. Thanks SB for sourcing the SMF and thanks to everyone who chimed in and responded to a few PM's. First clutch job complete !!
    7. #5
      Dec 2014
      Connecticut
      Quote Originally Posted by UT OLI View Post
      Hurrah! Success. Now go drive it but be gentle on her for a while.
    8. Remove Advertisements
    Similar Threads
    1. Engine swap and now clutch is slipping. No slip before job....
      By cervantes21 in forum S70, V70 & V70XC (1998-2000)
      Last Post: 11-12-2015, 03:53 AM
    2. Replies: 7
      Last Post: 09-26-2015, 06:48 AM
    3. She isn't finished, but getting there...
      By GiRaff3 in forum 850 (1993-1997)
      Last Post: 03-24-2010, 07:56 AM
    4. Finished a few things on my car but crashed into a curb!
      By ikorman in forum S70, V70 & V70XC (1998-2000)
      Last Post: 05-12-2004, 07:39 PM
