Loss of drive
    Results 1 to 15 of 15
    Thread: Loss of drive
      Jan 2020
      Loss of drive
      2005 V70 with a manual transmission. I was about to pull out of a parking lot, gave it a little gas in first, then I felt a pop and lost all drive. The transmission will go into any gear I put it in, but none actually work. If I grab the driver side axle, I feel a vibration while the car is idling. Currently waiting for my ride to pick me up. Any ideas on what it could be?
      Junior Member LukeFlynn's Avatar
      Feb 2019
      Knoxville, TN
      Quote Originally Posted by JedisonsDad View Post
      Clutch lol?
      Or one of the axles is broke.
      '04 XC70 | Silver Metallic/Nordkap 220K | Shimmed B5254T2 | K24 | M66 w/ SPEC single mass | IPD catback | Elevate sways | BC Coilovers | Hilton Stage 3 Tune
      '13 C30 T5M | Black Stone/Black | 135K | Stock
      Past - 09 S40 2.4I, 04 S60R M66
      Instagram - @boostedxc
      Jan 2020
      Doubt it’s the clutch, as it is a new clutch, maybe only 150 miles on it. Also, I wasn’t getting in it real hard, and I didn’t smell the clutch. Additionally, the axles only have 150 miles on them as well.
      SwedeSpeed.com
      Member Exocet's Avatar
      Nov 2017
      Southern Tier NY
      If an axle got overextended during removal and replacement, it could cause the joint to fail.
      Sent from my SM-G950U using Tapatalk
      2007 Volvo V70 2.5T - Mine
      2008 Nissan Titan SE 4x4, Crew Cab, Long Bed - Also Mine
      2012 Toyota Camry LE, 2.4 - Wife's
      2003 Mazda Protege5, 2.0 - Daughter #1
      2010 Mazda 6 Grand Touring, 2.5 - Daughter #2
    7. #5
      Oct 2014
      Boston
      The driver's side axle can also pop out if was not properly seated.
      05 XC70, 16 XC60 T5, 19 Tundra
    8. #6
      Jan 2020
      Quote Originally Posted by vtl View Post
      I’m hoping this is the case, especially seeing as how I can feel a vibration and wobble in the axle. Currently waiting for a tow truck. I can look at it more once it is in the driveway. I was planning on getting it in the air anyway, as my new drilled and slotted rotors come today.
    9. #7
      Senior Member ScottishBrick's Avatar
      Dec 2014
      Connecticut
      Axle popped out
      2003 V70 T5 - Mystic/Graphite - M56LK - 209k - K24/Greens/Do88/Quaife/SMF/P2R Clutch/DW300C/H&R/Bilstein TC/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 303k - Daily/Work Wagon
      1999 V70 T5 - Nautic/R Graphite & Alcantara - M56H - 177k - Rescued
      1999 V70 T5 - Emerald/Graphite - M56H - 119k - Garage Queen
      2000 V70 T5 - Mystic/Graphite - AW42 - 245k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 218k - Sisters
    10. #8
      Jan 2020
      Quote Originally Posted by ScottishBrick View Post
      Axle popped out
      Thankfully, this was the case. Driver side axle was popped out. Tomorrow I will be changing brakes and rotors, so I will use that time to seat the axle properly. Any tips? Apparently I didn’t do it right the first time....
    11. #9
      Dec 2014
      Connecticut
      Give it a good wack in. Should click when the circlip snaps in. You’ll also be able to see that there’s no lip seal wear surface exposed anymore.
    12. #10
      Jan 2020
      Should I just give it a good whack on the wheel side of the axle, being careful not to mushroom the splines?
    13. #11
      Oct 2014
      Boston
      Grease the splines and just use inertia to clip it in. Try to not "whack" it on the other side since you are risking damaging the CVs.
    14. #12
      Member
      Apr 2013
      Toronto, Canada
      If the circlip and splines are greased you should not need to use a hammer. Just forcefully push it onwards generating some momentum along the way. Then stick a pry bar behind it to verify that it’s in there solid.
      2010 V70 3.2 125,000miles
      2002 V70XC, 175,000 miles
      2004 S60 2.5T, 160,000 miles
    15. #13
      Dec 2014
      Connecticut
      Splines are hardened. Use a block of wood between your hammer and the splines though. Or use the block of wood as a hammer.
    16. #14
      Nov 2017
      Southern Tier NY
      Or a plastic hammer.
    17. #15
      Jan 2020
      Even with the wood, the wheel side splines mushroomed out and won’t fit back into the hub. Additionally, no matter what I do, the axle won’t stay in.
      I tried removing the axle entirely and re-spreading the c clip to make it larger, but still nothing. I even read something in the c70 forum I believe where it’s supposed to be a rounded c clip, not squared, so I added some bevels, and it worked better but I can still pull it out one handed with a beer can grip.
    18. Remove Advertisements
    Similar Threads
    1. Drive train loss
      By baxteR in forum R Forum (2004-2007)
      Last Post: 11-17-2008, 11:18 AM
    2. Anyone else experience loss of rear wheel drive?
      By rainmaker71 in forum R Forum (2004-2007)
      Last Post: 07-20-2006, 08:23 PM
    3. % of power loss in drive train
      By RhaRdeR in forum R Forum (2004-2007)
      Last Post: 06-04-2004, 08:06 AM
    4. Why dont any of my NY Dealers have an S60 R to drive/Sell or Test Drive?
      By EurotekDesigns in forum R Forum (2004-2007)
      Last Post: 06-16-2003, 03:07 PM
    5. Replies: 2
      Last Post: 07-17-2002, 11:16 PM
