1999 2000 V70R Blue Face Instrument Cluster
    Results 1 to 2 of 2
      Member Chicago_Wagon's Avatar
      Jan 2016
      Chicago, IL
      This tested and working cluster was removed from a MY99 V70R and shows 151,253 miles.
      The entire cluster is plug-and-play for all trim types of 1999 V70/S70, 2000 V70/S70, and 1999-2004 C70 vehicles. However, it will reflect the last recorded mileage of the vehicle from which it was removed. Alternatively, the blue faces themselves, without the backing electronics, can be swapped into your existing cluster to retain your actual mileage. The face-only swap can also be done with the existing cluster of 1998 V70/S70/C70 vehicles.
      The blue faces themselves are in excellent condition. As seen in the photos, there are some marks to the edges of the faces caused by the the circular portion of the front bezel, but this is hidden when they are actually installed behind the bezel. The clear portion of front housing also has some imperfections, especially in the lower right corner. Again, please see photos. However, the front bezel is easily exchanged with your current one as part of a swap.
      If interested in this item, please send me a PM and I will provide a link to it on eBay.
      $125 plus shipping.
      V70 S70 C70 R T5 GLT SE XC AWD V70R V70XC XC70
      Current - 2000 V70R 445/3876 | Past - 1998 V70 XC 421/3980 | RIP - 1986 RX-7 GXL WU/FD2
      Jan 2016
      Chicago, IL
      I took the time to take apart my dash and plug in this cluster to check it. Everything appears to function fine. Photo with the mileage is now in the original post.
    4. Remove Advertisements
    Similar Threads
    1. R face / watch dial face swap into base cluster
      By Phixion in forum S60 (2001-2010)
      Last Post: 05-19-2019, 04:41 PM
    2. 1999 V70R Blue Face Instrument Cluster - 211K
      By DWBF1 in forum FWD & AWD Parts For Sale
      Last Post: 07-01-2014, 10:57 PM
    3. 1999-2000 V70R Blue Face Speedometer Cluster
      By adamjjohn203 in forum FWD & AWD Parts For Sale
      Last Post: 04-14-2011, 03:19 PM
    4. Replies: 0
      Last Post: 04-07-2010, 08:07 PM
    5. 1999-2000 Volvo V70R Blue Face Cluster
      Last Post: 11-19-2009, 10:15 AM
