Mysterious coolant leak opinions
    Results 1 to 8 of 8
      Nov 2019
      Texas
      Need some opinions, im losing coolant semi rapidly and before someone says cracked sleeve, the coolant ISNT disappearing. Its leaking under the car, i got under there today and the only place I see any visible coolant is between the transmission and the angle gear.
      Any ideas where this could be coming from? Thermostat housing?
      I know its coolant because I use a red coolant and its red and my transmission fluid is not red.
      Need some opinions on where this could potentially be from since I was not aware on any coolant running near the collar sleeve etc.
      Sent from my SM-G965U using Tapatalk
      Sep 2013
      Georgia
      If you already checked the main the coolant lines from the radiator to the block, it could be the two heater hoses that go through the firewall (in the area behind/over the trans) or it could be a turbo coolant line. The turbo is basically sitting on top of the angle gear.
      2005 Volvo S60R AWD MT - Mystic Metallic Silver w/ Nordkap Leather
      Member qwkbrk's Avatar
      May 2010
      Northeast Indiana
      I would suggest not the thermostat housing. Here is a thread with my experience of that: How-To-Replace-Thermostat-On-The-R-With-Some-Pics
      '06 Long Roof R Magic Blue | Eroticama | 3-Pedal Arrangement | 231k miles | My story: Addicted to a new drug: torque, baby!!!
      '06 S2000 Berlina Black | Black | 27k miles - garage queen | RIP 10/05/17, now a parts car.
      '06 S2000 Berlina Black | Black | 28k miles - garage queen
      '07 Passat 2.0T Wagon | Deep Black | Wifemobile | 168k miles
      SwedeSpeed.com
      Nov 2019
      Texas
      Quote Originally Posted by qwkbrk View Post
      Awesome thsnk you, I think I had seen your write up actually haha.
    7. #5
      Nov 2019
      Texas
      Quote Originally Posted by Astro-R View Post
      The line itself or the gasket,?
      The odd thing is it seems to only happen after the car has been sitting for a bit.
    8. #6
      Sep 2013
      Georgia
      Not sure. Probably the gasket. Really just guessing without seeing the rough location of the leak. If its leaking at the turbo you may see residue from the coolant burning off.
      Have you jacked the car up and looked at the area from underneath? If you can't trace the leak, the next step would be to add dye to the system and use a uv flashlight to find the leak.
    9. #7
      Nov 2019
      Texas
      I'll take a look but when I was under there the drop built up was on the angle gear right where it connects to the trans. So it would probably be leaking from above.
    10. #8
      Jul 2018
      Potsdam, NY
      I had a coolant leak last winter (had to top if off every couple of days.) It was leaking down through front passenger side - turns out the bottom of my coolant reservoir was cracked.
    11. Remove Advertisements
    Similar Threads
    1. Mysterious Coolant Leak - Well Tread Soil . . .
      By m002922 in forum S40 & V50 (2005-2012)
      Last Post: 02-21-2020, 10:55 PM
    2. Mysterious Coolant Leak?
      By quicker in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 01-16-2018, 06:32 AM
    3. Mysterious coolant leak
      By GarrickL in forum R Forum (2004-2007)
      Last Post: 09-26-2015, 03:43 PM
    4. mysterious coolant disappearing
      By crums440 in forum R Forum (2004-2007)
      Last Post: 05-10-2012, 05:19 PM
    5. mysterious oil leak
      By Paddy Wagon in forum New Member Forum
      Last Post: 10-01-2006, 04:10 PM
