Cam upgrades on stock turbo
    Results 1 to 3 of 3
      Sep 2015
      Is it worth upgrading to enem y21 cams on a stock turbo?
      Member Austin V70R's Avatar
      Jan 2012
      Santa Cruz, Ca
      Quote Originally Posted by jorwood View Post
      Sure.... Y21 cams make a nice mid-range improvement. Be aware the swap is a very time consuming and somewhat expensive job if youíre not taking the head off the car. The cam base circle is different abs therefore requires lashing the valves. Itís best done by a machine shop who cuts the valve stem tips, but you can also do it with new lash caps at about $3.50 each.
      I built a spreadsheet to calculate lash cap thickness that Iíll share if you decide to do the job in the car, but be aware the job is a hassle.
      06 VR GT - daily driver ~18" TSW Nurburgring wheels ~Contrast Stage 4 ~Shimmed block ~EFR7163 turbo ~1050cc Injectors ~TorqByte PM3 fuel pump and CM5-LT W/M controllers ~track spec IPD Bars ~Ultra Racing front strut bar & VST rear strut bar ~SS brake lines~Innovate Boost & AFR fail safe
      Jan 2012
      Santa Cruz, Ca
      I need to clarify..... the followers are very expensive new, so Iíve found a local dealer who will sell them used for $3.50 each. Measure used followers with a micrometer before using them, but Iíve had very good luck.
    1. Access to rear of exhaust cam (to lock the cam)?
      By iRenaissanceMan in forum XC90 (2003 - 2014)
      Last Post: 02-02-2016, 11:16 PM
    2. Replies: 12
      Last Post: 05-07-2014, 12:45 PM
    3. Setting cam gears after removal of cam gears????????????
      By MFJ in forum R Forum (2004-2007)
      Last Post: 10-07-2013, 09:59 AM
    4. B230 ["A" Cam and RSI stg 2 turbo cam] Toronto
      By poy in forum RWD Parts For Sale
      Last Post: 09-19-2011, 03:25 PM
