TCM Replacement
    Results 1 to 8 of 8
    Thread: TCM Replacement
      Junior Member camc's Avatar
      Jul 2020
      TCM Replacement
      Hey guys, I just have a quick question.
      I am looking at replacing my Transmission Control Module on my 2006 s60r and I was wondering if I need to reprogram the ECU in order for it to adapt properly. I will most likely be buying a used one.
      Any help would be appreciated, thanks!
      Junior Member LukeFlynn's Avatar
      Feb 2019
      Knoxville, TN
      Quote Originally Posted by camc View Post
      They require reprogramming and usually will not take a reload if they are used.
      Why do you need to replace it?
      '04 XC70 | Silver Metallic/Nordkap 220K | Shimmed B5254T2 | K24 | M66 w/ SPEC single mass | EST Sport catback | Elevate sways | BC Coilovers | Hilton Stage 3 Tune
      '13 C30 T5M | Black Stone/Black | 135K | Stock
      Past - 09 S40 2.4I, 04 S60R M66
      Instagram - @boostedxc
      Jul 2020
      Well... not exactly replace, it is missing from this car.
      SwedeSpeed.com
      Jul 2013
      Georgia
      You might want to contact xemodex and see what solutions they can offer. A new TCM from Volvo, with programming is going to be expensive.
      Have you driven this car to make sure the transmission is ok? (at some point in the cars existence)
    7. #5
      Jul 2020
      Quote Originally Posted by hoonk View Post
      Yes, the transmission is fine. Is it still ok to drive on or will there be long term wear?
    8. #6
      Jul 2013
      Georgia
      I was not aware that a transmission on 99+ Volvo would work/shift/downshift without a control unit. (and have never tried)
    9. #7
      Feb 2019
      Knoxville, TN
      It won't, the car really won't even start without it because the TCM on 06+ with TF80 is also the PNP switch.
      Are you sure this car doesn't have a TCM? It's sitting right on top of the transmission underneath the shift linkage.
      2005 and below Rs have the TCM adjacent to the ECM in the box next to the coolant bottle, 06+ with the 6 speed auto have their TCM integrated into the top of the transmission.
    10. #8
      Jul 2020
      Quote Originally Posted by LukeFlynn View Post
      I feel stupid now... I have the 6 speed auto so I shouldn't have a problem at all, just myself overthinking as usual. Thank you all for your help regardless!
    11. Remove Advertisements
    Similar Threads
    1. CEM, ECU, TCM, BSM DIM, Steering Column Replacement
      By jubba in forum OBD, CANBUS & Engine Management
      Last Post: 05-22-2020, 11:57 AM
    2. 2001 v70 TCM 0020 and TCM 001F codes from VIDA
      By packetfire in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 07-22-2014, 02:02 PM
    3. TCM/Transmission module replacement
      By nzvlnr in forum S70, V70 & V70XC (1998-2000)
      Last Post: 05-12-2014, 08:56 AM
    4. 2001 V70xc - possible TCM replacement needed
      By Rockginxc in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 11-11-2013, 12:18 PM
    5. 4t65EV-GT Transmission issues TCM - 0024 TCM - 002B codes
      By Szpilman in forum S80 (1998-2006)
      Last Post: 03-22-2012, 05:27 PM
