HVAC weirdness
    Results 1 to 5 of 5
    Thread: HVAC weirdness
      Jan 2020
      HVAC weirdness
      2001 model -the a/c seems to have a mind of its own, blowing air from everywhere except where you want it, and on the occasion it does blow from the main vents, it's very unevenly distributed. Are some components (controls, flaps) prone to failing, and any trouble shooting tips for testing if the HVAC control is working properly, or the flaps are being obstinate?
      Jul 2013
      Georgia
      Quote Originally Posted by poohsan View Post
      There are all sorts of things you can do using VIDA - you can check damper positions, temp in each, reset damper motors, and many other parameters and setting. This would help with your diagnosis. From there you may find you need damper motors or perhaps a replacement CCM. Investigation with VIDA or an appropriate scan tool would be the first step.
      Jan 2020
      I saw the thread where I can dl the vida vm, I'm guessing I will need a funky cable connector too.
      I played with the a/c a little more, it always wants to blow on your feet. Hit the defrost button and the air blows on the windshield, then hit the middle button and the air blows from the dash vents, and about 1 minute later it switches back to the feet, even though the dash vents are still selected. Select the feet button where it's already blowing, and then switch back to the dash vents and it will blow from the dash vents for a few minutes, and then switch back to the feet again, even though only the dash vents button is selected.
      SwedeSpeed.com
      Jul 2013
      Georgia
      Yes you will need a Dice unit - It's the interface between your cpu and the car obd port.
      Volvo has in the past made the floor vents the default when something with the heater is broken - maybe so the floor heat will always work.
      You could look at what xemodex has to offer and check with them for suggestions - but Vida (with a dice unit) would give you answers also.
      https://xemodex.com/us/climate-contr...olvo-services/
    7. #5
      Junior Member Orange's Avatar
      Dec 2013
      If it mostly blows at the floor, it may be a dirty or a bad thermistor. The car battery must be disconnected when removing the module (suggest having the key in POSII when reconnecting). The thermistor must read 10kohm at 70F
      See youtube
    8. Remove Advertisements
    Similar Threads
    1. HU-803 Radio weirdness
      By ydowork in forum R Forum (2004-2007)
      Last Post: 04-15-2010, 07:13 PM
    2. PA-11 Weirdness
      By partridge in forum Car Audio, Video & Mobile Electronics Forum
      Last Post: 01-06-2006, 03:10 AM
    3. Speaker weirdness (blown etc)
      By nickraziz in forum S40 & V50 (2005-2012)
      Last Post: 01-02-2006, 06:41 PM
    4. Fuel Gauge weirdness
      By SirSteak in forum S40 & V50 (2005-2012)
      Last Post: 09-08-2005, 10:50 AM
    5. Rear suspension weirdness
      By Britspeed in forum R Forum (2004-2007)
      Last Post: 06-02-2004, 12:05 PM
