XC70 2002 engine oil cooler & transmission oil cooler
    Page 1 of 2 1 2 LastLast
    Results 1 to 35 of 46
      Junior Member aussiesteve's Avatar
      Apr 2014
      Sydney Australia
      Starting to warm up in Australia and noticing temp gauge running hotter, air conditioning makes it worse. Anyone have any recommendation or experience with connecting and location for a remote engine oil cooler and the same for transmission.
      Quote Originally Posted by aussiesteve View Post
      Look at elevates site for ideas
      Senior Member ScottishBrick's Avatar
      Dec 2014
      Connecticut
      D5 oil cooler is 40% larger and bolts on.
      2003 V70 T5 - Mystic/Graphite - M56LK - 211k - K24/Greens/Do88/Quaife/SMF/P2R Clutch/DW300C/H&R/Bilstein TC/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 305k - Daily/Work Wagon
      1999 V70 T5 - Nautic/R Graphite & Alcantara - M56H - 177k - Rescued
      1999 V70 T5 - Emerald/Graphite - M56H - 119k - Garage Queen
      2000 V70 T5 - Mystic/Graphite - AW42 - 246k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 218k - Sisters
      SwedeSpeed.com
      Member Exocet's Avatar
      Nov 2017
      Southern Tier NY
      Transmission oil cooler.
      Sent from my SM-G950U using Tapatalk
      2007 Volvo V70 2.5T - Mine
      2008 Nissan Titan SE 4x4, Crew Cab, Long Bed - Also Mine
      2012 Toyota Camry LE, 2.4 - Wife's
      2003 Mazda Protege5, 2.0 - Daughter #1
      2010 Mazda 6 Grand Touring, 2.5 - Daughter #2
    7. #5
      Oct 2014
      Boston
      Look at this thread for the hood louvers locations: https://forums.swedespeed.com/showth...92s-XC70-build Whatever cooler you install, it is superhot under the hood with T2 engine - must ventilate.
      05 XC70, 16 XC60 T5, 19 Tundra
    8. #6
      Apr 2019
      Western North Carolina
      [QUOTE=Exocet;7676729]Transmission oil cooler.
      Are those PEX elbows & clamps??
      This is on my weekend task list, wanted elbows like you used, went to McMaster Carr usually a great source, but all they had in brass is called low pressure Off to the basement to look! perfect timing, tracking shows the rest of the stuff from Summit Racing is due tomorrow. I like the thought of only using two screw clamps at the Magnafine filter. I did the Hayden 11 x 9 with thermostatic control.
      Thank You
      2007 XC70 2.5T
      1964 International Scout 80, 1966 912 Porsche, 1967 912 Porsche SW Targa, 1967 250S Mercedes, 1971 911 Porsche Targa, 1986 Chevy 4x4 short bed PU
      1973 R75 BMW, 1981 R100RS
    9. #7
      Nov 2017
      Southern Tier NY
      Brass elbows. A combination of PEX and Oetiker clamps. I'm planning on replacing the elbows with aluminum tubing for more gradual bends. Transmission fluid isn't under high pressure. Maybe 10 PSI.
    10. #8
      Apr 2019
      F--ing Brilliant! Makes for very neat install, I checked some 1/2" Pex 90's and the size looks great for the 3/8 rubber trans line.
      Thanks for posting! id as normal I would see that a week after doing the install.
      Best Regards
      2007 XC70 2.5T
    11. #9
      Nov 2017
      Southern Tier NY
      I have 3/8" fittings and the hoses fit pretty tight. I wanted to keep all of the hoses behind the crash bar - neater and less risk of damage.
    12. #10
      Jul 2020
      Seattle-ish
      Here's a thread with some other transmission install considerations:
      https://www.volvoxc.com/forums/showt...mission-Cooler
      I put a transmission cooler in my 2004 a few weeks ago. Other things I'd do while it was open would be too swap the o-rings on BOTH the in & out fittings on the radiator. They shrink and harden over time. Two on each fitting. These o-rings (I'm sure generic will do and can be found - 11 x 2 mm):
      https://www.rmeuropean.com/Products/...325-V4754.aspx
      Many suggest having an extra clip if you remove the connector, like this (I had no issue getting them off):
      https://www.rmeuropean.com/Make/Volv..._-_at_Radiator
      Adding a magnetic in-line filter like this is not a bad idea when you are there plumbing anyway (I put one in the PS system, too - plenty of room/easy access in the return hose along the firewall):
      https://www.amazon.com/Raybestos-515.../dp/B072PQ2XKD
      I found fluid cheapest at my Total dealer, 10qts for $53 US after tax, ask for the T-IV which is what Volvo-rebrands (technically actually Mobil JWS 3309 originally).
      I find Mubea clips/ct clamps so much easier to use and hold better in applications like this. There are cheap generic ones in bins at my local 'Ace' hardware store:
      https://www.original-mubea.com/en/products/
    13. #11
      Nov 2017
      Southern Tier NY
      I added an external, screw on filter. Right in front of the LF wheel. Easy to change!
    14. #12
      Apr 2019
      The Pex 1/2" fittings measure just under 3/8", looks to be perfect and will copy your routing behind the crash bar
      Thanks again for posting!
      2007 XC70 2.5T
    15. #13
      Member
      Apr 2013
      Toronto, Canada
      Quote Originally Posted by Exocet View Post
      Ah man love the screw-on filter! Great idea!
      2010 V70 3.2 125,000miles
      2002 V70XC, 175,000 miles
      2004 S60 2.5T, 160,000 miles
    16. #14
      Nov 2017
      Southern Tier NY
      Quote Originally Posted by bigtimemcalpine View Post
      Beats pulling the transmission out and cracking it open to replace the filter!
    17. #15
      Jan 2017
      Berkeley, CA
      I added the 11 x 6 Hayden cooler, mounted in the same place as Exocet shows above. I believe this kit had everything that I needed:
      https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    18. #16
      Oct 2014
      Boston
      Quote Originally Posted by Oro-o View Post
      Volvo ATF is not Toyota T-IV, nor Mobil 3309.
    19. #17
      Apr 2019
      [QUOTE=bigtimemcalpine;7677263]Ah man love the screw-on filter! Great idea!
      Yes, also more fluid & more cooling, need to check the garage for a spin on adaptor I pulled off the 66 Pcar and added a Canton Racing 8 micron filter, or if I can find one in town tomorrow. Move the Microfine to the PS line as suggested.
      Thanks to all
      2007 XC70 2.5T
    20. #18
      Jul 2020
      Seattle-ish
      Quote Originally Posted by vtl View Post
      Yes, it is. The factory fill for this was JWS3309; a 2002 XC70 has an Aisin AW55-50 (AW33, etc.). Volvo has a unique internal part number is the only difference (Volvo is 1161540-8). For non-Aisin Volvo-installed transmissions, this does not apply.
      https://www.ipdusa.com/products/1054...atf0t4-1161540
    21. #19
      Oct 2014
      Boston
      JWS 3309 is a standard.
      Mobil 3309 is a product compliant to the standard. Mobil 3309 differs a lot from Volvo 1161540/1161640. T-IV is closer, but not there yet.
      Aisin 0T4 differs from Volvo even more.
      I've burned about $1k experimenting with cheaper alternatives to expensive Volvo ATF, and have tried many choices. Among these four mentioned ATFs, Volvo is the top choice, then T-IV > Mobil > Aisin. I would actually put Idemitsu Type-TLS before T-IV, but Volvo is still better, because it has a slightly higher viscosity and a better friction modifiers pack.
    22. #20
      Member Antherzoll's Avatar
      Dec 2013
      Toronto
      A true lifetime performance fluid!
      2005 XC70 Crystal Green | Hilton | 16T | Bad Swede | 145k mi
    23. #21
      Oct 2014
      Boston
      Quote Originally Posted by Antherzoll View Post
      Yes, transmission is filled for lifetime. The lifetime of the fluid, not transmission
      Really, it costs $50ish for 4l, you need one like every other year.
    24. #22
      Dec 2013
      Toronto
      I do 12L of T-IV every 30k. Still pink like a peach when I do the changes but I want to make sure I get all of the old out.
    25. #23
      Oct 2014
      Boston
      Modifiers wear out more quicker than ATF gets dark. Especially, with the inline filter installed.
    26. #24
      Apr 2019
      Went to the dealer this afternoon for a few bits in case something was to break and get fluid, what a waste of time, They had no fluid!, no spare O-rings of clips for the quick disconnects, they had 2 of the plastic rivet / pins for the top of the bumper but on closer inspection they are not correct. So much for them and picking anything up locally.
      Will pick up L of the T-IV or mobile to top off after the filter & cooler install and order some on line later for a change, color is good had it serviced about 25K miles ago with Volvo fluid.
      Thanks for the tips.
      2007 XC70 2.5T
    27. #25
      Apr 2014
      Sydney Australia
      Quote Originally Posted by ScottishBrick View Post
      Hi Scottishbrick, Thanks for the info When you say D5 oil cooler I take it you mean engine oil cooler. Is the D5 cooler on a XC70 the same as on an XC90 Thanks
    28. #26
      Dec 2014
      Connecticut
      Yes. Visually verify the coolant outlet and inlet orientation but I believe that they are the same.
    29. #27
      Like the filter as well. Why not use AN swivel fittings for easier maintenance/removal for future instead of the compression clamps?
    30. #28
      Nov 2017
      Southern Tier NY
      Quote Originally Posted by paradoxicallymodified View Post
      Yes, I looked at the AN fittings. While nice, it ultimately came down to cost and how many times will I ever take it apart - probably never.
    31. #29
      Apr 2019
      [QUOTE=Exocet;7678199]Yes, I looked at the AN fittings. While nice, it ultimately came down to cost and how many times will I ever take it apart - probably never.
      Agree, you start with Push on connectors at the cooler and also need them to get into & out of the fluid system and the spin on adaptor keeps from taking it apart. I like and use AN fittings a lot, over time I have quit using AN swivels as they almost always weep oil.
      Best Regards
      2007 XC70 2.5T
    32. #30
      Correct. I meant barbed or AN not swivel. Misspoke. Apologies
    33. #31
      Nov 2017
      Southern Tier NY
      No worries. If it was someplace visible, I might have used AN fittings and hose, just for cosmetics.
    34. #32
      As often as we pull the motor on the drag car we always have to think about more or less quick disconnects of some sort
    35. #33
      Jul 2020
      Seattle-ish
      I've put about 500k miles on Aisin AW33, AW55-"X", Aisin U151e (non awd main case) on multiple cars. Never seen Aisin spec something different. Never had a failure, and in regard to Volvo, seen big improvements dumping Volvo dealer fill (unknown actual provenance) and putting in real 3309.
      Love to learn if you can demonstrate; always open to being wrong.
      Can you reference anything? The single UOA of Volvo fluid was disastrous, it sheared terrible.
    36. #34
      Apr 2019
      Update: I like Exocet's filter location looks easy change the filter pulling 1 splash guard, 1 bolt, BUT PITA to drill it, but all good & mounted. Started late yesterday first time bumper cove removed, 20 min alone taking my time, I can see doing this to change headlamp bulbs as foolish as it sounds :-)
      Mounting my cooler lower using the holes at the bottom outside of the ac evaporator for cross support, will figure out other brackets & final hose routing tomorrow, no work today for a memorial service for a very dear friend
      Best Regards
      2007 XC70 2.5T
    37. #35
      Nov 2017
      Southern Tier NY
      Don't even have to remove the splash guard to remove the filter. Just reach up behind bumper cover. Yes, it was a PITA to drill. I only got 2 of the 3 screws in.
    38. Remove Advertisements
    Similar Threads
    1. ATF cooler and Engine oil cooler
      By S60WQH in forum S60 (2001-2010)
      Last Post: 01-15-2018, 06:17 AM
    2. My noise(s) #*$&*()&#$(*&($*%&(*$(&% My rant of the day!
      By JRL in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 04-24-2016, 09:26 AM
    3. "Drift Assist"?
      By Fmfosnacht in forum XC90 (SPA: 2016 - )
      Last Post: 12-02-2015, 01:47 PM
    4. P4 xc70 p4 xc70 p4 xc70 p4 xc70 p4 xc70
      By CrossingCountries in forum V70 & XC70 (2008 - 2016)
      Last Post: 10-09-2015, 11:21 AM
    5. towing Q/transmission cooler needed? 2002 XC70
      By jrevkin in forum General FWD & AWD
      Last Post: 06-25-2007, 10:25 AM
