Heater Hose Coolant Leak at Firewall
    Results 1 to 6 of 6
      Sep 2015
      2004.5 S40 T5 has a heater hose leaking at the firewall. I know there have been some posts on this in the past, but don't see a sticky and not finding the posts I thought I had saved. Which hoses should be replaced and any details on how to replace? Appreciate the assistance.
      Thanks
      Member jondevieonS40's Avatar
      Oct 2011
      ABQ New Mexico
      It’s not a usually a hose it’s the gasket that’s in the hose, under the glove box area. The hose passes thru the firewall into the cabin where there you will see some clamps, that is usually the point of failure of the heater core itself.
      [2005 Volvo S40 2.4i][2008 Volvo S40 T5 AWD][2008 Volvo C3 T5 2.0 RS Build][2009 Volvo V50 T5 AWD R-Design][1987 Buick Grand National] "embody God, then go crazy"
      Junior Member Facusan's Avatar
      Nov 2014
      Houston, TX
      In my case, the quick connectors of the heater hoses were leaking. The plastic was disintegrating and was ready to let go. When I tried to disconnect them they broke. I ended up replacing those four hoses with genuine new ones that came with new connectors. It took me 1 hour to complete the job.
      The hoses were fine. I could’ve just replaced the connectors with metal pipes and hose clamps as an alternative fix.
      SwedeSpeed.com
      Member AutoGeek's Avatar
      Jan 2008
      MD, Howard Co.
      Mine disintegrated so I replaced them with brass unions. No worries now.
      2005 V50 T5 FWD M66 Passion Red (Radio Flyer) Bilstein HD, ECU spacer, Snabb Turbo Pipe
      1998 V70 NA - Sold, 2002 S40 1.9T - R.I.P., 2005 V50 T5 - RIP
      Remember kids, Speed doesn't kill ... impact does!
    7. #5
      Sep 2019
      I was just thinking about that weakness in the cooling system that as I just got my blue silicone radiator hoses from VIVA in the mail. I think I will try to find brass unions as well. Are they available at Home Depot or Ace Hardware ?
      Sent from my Pixel 2 XL using Tapatalk
    8. #6
      Sep 2019
      This looks like it might fit in between the heater hose ends at the firewall and replace the plastic couplings
    9. Remove Advertisements
    Similar Threads
    1. S40 Awd T5 2006 heater hose leak?
      By Aza510 in forum S40 & V50 (2005-2012)
      Last Post: 03-22-2019, 05:35 AM
    2. Easiest routing thru firewall for a boost gauge hose ?
      By za.S60R in forum S60 (2001-2010)
      Last Post: 04-11-2017, 10:59 AM
    3. Block heater / engine coolant heater ?
      By xiar in forum S60 (2001-2010)
      Last Post: 12-08-2012, 06:41 PM
    4. Replies: 16
      Last Post: 01-11-2011, 01:47 AM
    5. Blew coolant hose - head to heater valve.. help!
      By yieldsign2 in forum 740 & 760 (1982-1992)
      Last Post: 09-06-2005, 05:29 PM
