Noticed a leak in the exhaust tracked it down and the cause also. Looks like I need to replace the down pipe as the flex part is leaking due to the hanger on the rear portion near the fuel tank has broken away. Question is there a upgrade to the 95 Turbo down pipe or do I have to swap the turbo housing to swap for an upgraded one? Is it worth the turbo swapping? are they no mod swaps or have to make some changes to get them to work also what turbo will fit? thanks in advance guys I know this is a lot but any little bit helps.
