LED bulbs for brake, reverse, and turn signals?
    Results 1 to 10 of 10
      Member sventastic's Avatar
      Nov 2013
      British Columbia
      What’s everyone using to light up your ass end?
      I finally wired up my reverse lights, 2 years after my manual swap I’d love to get LEDs for the whole back end, at the very least for the reverse lights
      1996 854R | M56H | 16T | 271k
      Jul 2013
      Georgia
      Quote Originally Posted by sventastic View Post
      If you use led bulbs for brake and parking lights - you will be fighting the bulb failure lamp - if you use them for turn signals they might flash too fast. To fix the now constant bulb out warning - the easiest thing would be to take the dash off and remove the bulb out warning bulb from the instrument cluster.
      On a side note - then you could put some aftermarket HIDs, leave them on all the time to show them off and blind everyone all the time! Put some bright blue ones in - those are particularly annoying.
      Moderator The Driver's Avatar
      Sep 2009
      Huntington, NY
      My R completely LED, just use resistors or high. enough wattage LEDs and your fine.
      06R Custom Electric Blue Silver
      07R Magic Blue - Sold
      04 Bonatti Gray Rover Disco HSE
      09 Iridium Silver SLK55 AMG P30 Edition
      SwedeSpeed.com
      Nov 2013
      British Columbia
      Quote Originally Posted by hoonk View Post
      I was thinking that could be a problem. The main ones I care about are the reverse lights, anything else would be a bonus.
      Lol, I installed LED low beam bulbs about a month ago and they’ve been fantastic, definitely not blinding since I have them aimed properly, but the beam pattern isn’t as crisp anymore unfortunately.
      Quote Originally Posted by The Driver View Post
      What kind of wattage?
    7. #5
      Sep 2009
      Huntington, NY
      50+ Watt usually work. That said for real 50's you'll be paying 40+ dollars a bulb.
    8. #6
      Jul 2013
      Georgia
      Yep, you will be better off (that is able to see what you are about to hit!) if you just use what bulbs the headlamp was designed for. (but I know, led's are cool!, who cares if you can't see where you are going, just don't drive at night)
    9. #7
      Senior Member ScottishBrick's Avatar
      Dec 2014
      Connecticut
      For reverse (on every damn volvo weve got and then some)
      https://www.amazon.com/JDM-ASTAR-Ext...b-8a79de2d236f
      Work great.
      2003 V70 T5 - Mystic/Graphite - M56LK - 211k - K24/Greens/Do88/Quaife/SMF/P2R Clutch/DW300C/H&R/Bilstein TC/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 305k - Daily/Work Wagon
      1999 V70 T5 - Nautic/R Graphite & Alcantara - M56H - 177k - Rescued
      1999 V70 T5 - Emerald/Graphite - M56H - 119k - Garage Queen
      2000 V70 T5 - Mystic/Graphite - AW42 - 246k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 218k - Sisters
    10. #8
      Senior Member JaredR's Avatar
      Jan 2014
      Boston, MA
      +1 on LED reverse lights^
      I see no advantage to LED turn signals and the 3rd brake light is already LED.
      LED headlight bulbs are great.
      Quote Originally Posted by JaredR View Post
      1995 850 T-5R Estate. AW50-42LE. Cream Yellow/Graphite. 297k.
      1997 850R Estate. B5234T9/M66D. Bright Red/Graphite. 280k.
      2007 S60 T5. M66W. Black Sapphire/Arena. 141k.
      Instagram: Jared's Volvo Page
      Past: |1997 855R. Bright Red/Light Beige. AW50-42LE. Totaled by wayward construction equipment. || 1996 854R. Black Stone/Graphite. AW50-42LE. Parts car || 1995 854 TURBO. Polar White/Tan. AW50-42LE. Parts car. |
      Dad: 1997 V70 T5 SE. AW50-42LE. Frost Green/Oak. 212k.Mom: 1999 S70 GLT Pewter/Oak. 101k. Past: 2004 V70 NA. AW55-50SN Ruby Red/Tan 269k. Sold to markj
    11. #9
      Junior Member Zoinks's Avatar
      Jul 2018
      Milwaukee, WI
      Quote Originally Posted by ScottishBrick View Post
      Work great.
      I've been meaning to ask what LED reverse bulbs you guys use, I'll be ordering a couple sets of these now.
      Proper LED headlights are the way to go, I still rock halogen high's but even $25 LED's from amazon have been doing as well as the $120 Morimoto bulbs I had on my old red wagon. Not the best shot, because I’m so close to the wall and it was like noon, but still a visible difference
      I would like to investigate LED running lights before turns & brake lights.
      1999 V70 T5m Classic Red/Graphite
      1998 V70R Mystic Silver/Graphite
      1996 RN Swapped 854R Bright Red/Graphite
      Family Fleet:
      2009 C30 T5 R-Design M66 Silver/Two-Tone
      Past:
      1998 V70 NA/m Classic Red/Light Gray
      2000 S40 1.9T White/Cloth
    12. #10
      Nov 2013
      British Columbia
      Work great.
      Perfect, thanks Will!
    13. Remove Advertisements
    Similar Threads
    1. Replies: 13
      Last Post: 06-22-2017, 08:19 AM
    2. LED Reverse Light Bulbs
      By MyNameIdeasWereTaken in forum Miscellaneous Classifieds
      Last Post: 06-26-2014, 06:12 AM
    3. flasher, brake lights and turn signals not working
      By greendread in forum Amazon P120, P130 & P220 (1956-1970)
      Last Post: 06-01-2014, 05:48 PM
    4. yay or nay: led turn signals (vid)
      By o2k in forum R Forum (2004-2007)
      Last Post: 09-27-2009, 11:02 AM
    5. Silver turn signals - what bulbs are you using?
      By 23109VC in forum R Forum (2004-2007)
      Last Post: 04-13-2005, 12:12 PM
