Xc90 Cooling Fan In-op
    Results 1 to 8 of 8
      Sep 2020
      Good Evening Folks;
      My first posting here, but I admit to having poached some very helpful information from you over the years. The issue at hand here is that my daughter's XC90 2.5 5 cylinder's electric cooling fan appears to have failed. I have swapped it for a supposedly good one from a local recycler with no joy, and the question I have for you assembled Volvo experts is where is the fan relay / controller located? I have looked all over the engine compartment and cannot see a likely suspect. With colder weather here in Eastern Canada the fan is not as necessary as it was in July, but I do want it fixed.
      Best regard and thanks;
      Mike Coleman
      North Lancaster, Ontario
      2004 Volvo XC90
      A bunch of diesel Mercedes, Dodge Cummins pick-up and several motorcycles
      Good memories of long gone 240 and 740 Wagons.
      Jul 2020
      Portland, OR, USA
      My guess would be the fuse is blown. Check the fuse box in the engine compartment, its cover has a diagram printed on the inside of it that shows which fuse pertains to which part. It also has a few spare fuses in there and a handy fuse puller.
      http://www.volvohowto.com/volvo-xc90...-and-amperage/
      Sep 2020
      Hello, thanks but that is the first thing I checked. A full 13+ volts at the big red wire.
      Thanks anyway
      Mike
      SwedeSpeed.com
      Jul 2015
      Calgary
      Isn't the fan/blower motor/resistor all part of the same unit? When ours became intermittent I got another complete assembly from the auto wrecker and it has been working good since installation. 04 fit into the 07. A funny quirk was that when I raised and dropped the hood the intermittent one would start working again. Probably it was in the wire connection. I changed the connector pig tail at the same time.
      07 XC90 3.2
    7. #5
      Sep 2020
      Hi Vince, yes it is all part of one assembly, so I have been told. I did as you did, changed the entire assy, but still no blow. I have been told that it is an ECM problem, so I see a trip to the dealer in my future.
      Thanks
      Mike
    8. #6
      Oct 2018
      San Diego, CA.
      Looking at the wiring diagram, it appears that there is a separate temperature sensor and an AC pressure sensor involved, as well. I would start by applying an ohmmeter to the temp sensor. Open circuit is bad; should have some level of resistance?
      2009 XC90 FWD 3.2, 2013 S60 T5
      In the past: '89 745, '91 940, '82 242, '67 122S, '67 123GT, '71 142E, '62 PV544.
    9. #7
      Sep 2020
      Hello, the temp sensor on the thermostat housing? I happen to have a spare, I will check the one on the car and swap them if necessary .
      Thanks again.
      Mike
    10. #8
      Oct 2018
      San Diego, CA.
      The diagram doesn't share the location, but that may be a winner. Good luck!
    11. Remove Advertisements
    Similar Threads
    1. Replies: 3
      Last Post: 10-18-2014, 04:41 AM
    2. An XC photo op.
      By Frosted_v40 in forum General FWD & AWD
      Last Post: 08-06-2013, 08:37 PM
    3. Rescue Op for Journalist
      By greek2us in forum Off Topic Forum
      Last Post: 09-15-2009, 07:11 AM
    4. Quick R + M + S photo op...
      By m3nt0s in forum R Forum (2004-2007)
      Last Post: 01-07-2008, 03:53 PM
    5. Replies: 0
      Last Post: 09-29-2005, 02:54 PM
