2008 XC90 V8 AWD Spark Plug Change/Crankcase Filter/Fluid Change Info
    Results 1 to 9 of 9
      Jul 2020
      Portland, OR, USA
      2008 XC90 V8 AWD Spark Plug/Crankcase Filter/Fluid Change Info
      Hi all,
      Replacing the sparkplugs on my 2008 Volvo XC90 V8 w/70K miles as per routine maintenance. I bought these sparkplugs: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
      I've heard that you need a torque wrench for this job. How do I know what spec to torque the plugs to?
      Furthermore, I read on DriverSide.com that I need to do a crankcase fluid change as well as a crankcase oil filter change. Anyone have experience with these? Are they doable by yours truly, a higher-than-average home mechanic? What parts would I need for this replacement? Tools? Any helpful videos, etc.?
      Thanks in advance, everyone. Cheers!
      Nov 2017
      Auckland, New Zealand
      Quote Originally Posted by 08XC90V8 View Post
      Hi all,
      it's all quite doable by home mechanic, the rear banks are slightly harder to reach but not too crazy. Get a telescope mirror if you're more visual than tactile type.
      Pry any plastic parts carefully as they do get quite brittle, I think I broke one clip.
      I changed mine at just under 70k miles (110k km). Didn't run into any issues. Sore back though, good luck!
      2011 XC90 B8444S R-Design 614 120k km RHD
      You don’t need a torque wrench. The plug package will tell you how to tighten. Usually it’s hand tight then a 45-90degree turn with a wrench.
      2010 XC90 V8 - 140k miles
      2012 S60 T5 - traded with 177k. Lost compression on cyl 5.
      2009 C30 - Totaled. It ate a minivan at 35mph.
      2006 S40 - at 217k it was tired and needed too much.
      2008 XC90 3.2 - traded with 220,780 miles
      SwedeSpeed.com
      Jul 2020
      Portland, OR, USA
      Quote Originally Posted by kiwiV8 View Post
      Good to hear, thank you so much!
    7. #5
      Jul 2020
      Portland, OR, USA
      Quote Originally Posted by Masscomguru View Post
      Okay, thanks. That means I don't have to buy a torque wrench now!
    8. #6
      Thats what I was taught - as tight as your fingers will manage, then another 45° for bevelled plugs and 45-90° for plugs with a crush washer.
      2009 XC90 D5 185 R Design Geartronic-6
      Premium, Summer, Winter, Family and Comms packs.
    9. #7
      Global Moderator R-Pow3R3d's Avatar
      Apr 2015
      Pittsburgh, PA
      2007 XC90 V8 Sport Passion Red/Off-Black - Serpentine Belt, Tensioner & Idler Pulleys - Spark Plug Replacement - Y-Pipe Replacement
      1990 745 Turbo Intercooler White/Beige
      2007 XC70
      VIDA/DICE Owner - SS Lurker Since 2009 - '06-'07 Transmission Valve Body Info - SR/VR Failing Throttle Body - Replica 18" Pegs - Handbrake Mod
      Current Non-Volvo: 2007 VTX 1800 F3, 2002 VT750DC
      Previous: 2006 S60R, 2004 V70R MT 68k
    10. #8
      Sep 2018
      Crankcase fluid is a weird word for engine oil and crankcase filter is an odd thing to call what is commonly known as an oil filter.
    11. #9
      Jul 2020
      Portland, OR, USA
      Quote Originally Posted by brich999 View Post
      Really??? That's really weird! I thought I'd have to do a lot more work than just the oil and oil filter! Thanks so much! Any idea on how hard the process is?
    12. Remove Advertisements
    Similar Threads
    1. V8 XC90's (Including V8, V8 Sport, V8 R-Design)
      By R-Pow3R3d in forum FWD & AWD Cars For Sale
      Last Post: 10-20-2020, 02:22 PM
    2. 2008 XC90 Spark Plug Gap
      By bhertel in forum General Volvo Discussions
      Last Post: 09-04-2019, 12:37 PM
    3. 2008 Volvo XC90 4.4 V8 Spark Plug Replacement
      By pjchristopher in forum XC90 (2003 - 2014)
      Last Post: 06-25-2014, 08:55 PM
    4. Replies: 7
      Last Post: 07-03-2007, 10:11 PM
