Leak at rear differential 04 S60R
    Results 1 to 8 of 8
      Junior Member alexk243's Avatar
      Sep 2015
      Chicago, IL
      Was changing out my exhaust and noticed a bunch of oil on the bottom of the rear differential. I have fluid and filter change kit ready to do the haldex service, but I'm concerned about this fluid leak. Anyone have any idea where the leak is coming from and how easy it is to fix?
      No noticable leak from the front seal where the shaft goes into the differential.
      2004 Volvo S60R
      KulAdventure.com
      Junior Member shurgen's Avatar
      Apr 2007
      Valley Forge, PA
      That looks filthy. Leaks are generally from seals where axles go into rear diff. See if you have any fluid left. There is a fill/drain/correct-level bolt to the left side. If you hear any humming noise coming from rear when driving you may end up needing a differential. If so, look for local part out, it's challenging but not very difficult to change. I got one on VR for parts that will be sent to junker next week but shipping would kill any deal.
      04 V70R Red/Atacama, 100k miles, M66, Rica 2, Elevate DP and sways, JRL mod, 3"CAI, Viva CBV, Heico V's.
      06 V70R Sonicama, 135k miles, GT, MTE stage 2, IPD DP and sways, MTE catback
      07 V70R Titanium/Nordkap, 142k miles, M66, Elevate DP, Heico catback, IPD sways, PDV collar, Heico V's
      Junior Member Rodtheviking's Avatar
      Jun 2019
      Vancouver, WA
      Mine was doing the same, just had the two axle seals done, no more leak. I had to have a shop do it as they are a pain in the ass to get to and I don't have a lift.
      SwedeSpeed.com
      Sep 2015
      Chicago, IL
      Man... That's a bummer to hear. It looked really clean on the front where the axle went in... But may be worth a second look.
      No driving symptoms yet.
      2004 Volvo S60R
      KulAdventure.com
    7. #5
      Jun 2019
      Vancouver, WA
      Its pretty wet, you might want to check oil level before you cook the diff.
    8. #6
      Sep 2015
      Chicago, IL
      Quote Originally Posted by Rodtheviking View Post
      Yeah I plan to, but the fluid is really expensive and would like to fix the leak first. Any ideas on where to look besides where the shaft goes in?
      2004 Volvo S60R
      KulAdventure.com
    9. #7
      Jun 2019
      Vancouver, WA
      Take the wheel off and you can see where the cv shaft goes in on either side. The fill plug is on the back up by the muffler, its a pain to fill. Get a transfer pump from Harbor Freight it will make it easier. Mobile 1 GL5 synth gear oil is fairly cheap at WalMart.
    10. #8
      Apr 2012
      Austria
      After I replaced both axle seals mine was still leaking.
      Had to take the housing appart and reseal it.
      Dry rear diff for 3 years now.
      Volvo S60R M66 MY2004
    11. Remove Advertisements
    Similar Threads
    1. Rear differential oil on case,no leak.
      By osteovolvo in forum S60 (2001-2010)
      Last Post: 09-27-2018, 08:10 PM
    2. 2000 v70r rear differential leak
      By brickhead in forum S70, V70 & V70XC (1998-2000)
      Last Post: 11-03-2015, 03:33 PM
    3. Rear differential leak
      By k22 in forum S40 & V50 (2005-2012)
      Last Post: 06-01-2015, 05:53 AM
    4. Rear differential fluid type 04 XC70
      By mcleoddude in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 04-25-2013, 10:16 AM
    5. 04 S60R Rear Differential
      By ClemsonS60R in forum FWD & AWD Parts For Sale
      Last Post: 05-25-2010, 04:27 PM
