Rubber piece on the sunroof is peeling off
    Results 1 to 15 of 15
      Mar 2018
      DeKalb, Illinois
      Observed this today while cleaning the car. Will it result in water leak? Owned this for about 1.5 years and didn't put anything on the roof, so not sure if it was there before purchase or how it happened. Didn't observe anything leaking at the moment but don't want to wait till it starts leaving bad. Also is this something easy to replace or going to cost a lot. I have CPO warranty and not sure if this will be covered through it.
      Our first Volvo - Optimus Prime - 2016 XC90 T6 Momentum Onyx Black, HUD, Momentum+, Convenience, Vision, Climate, Pilot Assist II + Mitigation Upgrades + Jan 2020 Update
      My Fuel Log for real life Optimus Prime fuel efficiency - http://www.fuelly.com/car/volvo/xc90...wdarygm/910536
      Jun 2018
      Heck yeah there will be a leak. Get that replaced unless u live in the desert.
      Sid
      2019 Volvo XC90 T6 OSD
      2007 Porsche 911 Turbo
      2004 Dodge Viper SRT-10
      2012 Ducati Diavel
      Jul 2016
      I have the same issue on my car. I wonder why it's wearing prematurely.
      Sent from my SM-N975U using Tapatalk
      SwedeSpeed.com
      Feb 2016
      The extended warranty doesn’t cover weather strips. CPO warranty maybe the same. It looks like #2 front weather strip:
      https://www.oemvolvopartsonline.com/.../body--sunroof
      Make sure drain tubes aren’t clogged. You can do that by pouring a bottle of water in the sunroof rails on each side when the sunroof is opened. Water will be drained to the bottom of the car. You may need to ramp up the front to test rear drain tubes. I just did this the other day since the strip gap is getting wider..
    7. #5
      Member satrya's Avatar
      Jan 2018
      Fremont, north california
      Yes, you should get that replaced.
      I'm not convinced that it necessarily causes leaks though. The rubber piece should be there to reduce the volume of water going through the moon roof drain system, but not prevent water from going into the drain system.
      A clogged drain tube (as discussed in other threads) is probably more likely to cause leak than that.
      Denim Blue 2018 xc90 T6 Momentum+
    8. #6
      Mar 2018
      DeKalb, Illinois
      Thank you all for the inputs. Any idea how much this might cost at the dealer?
    9. #7
      Jul 2016
      This is a warranty issue. It shouldn't be wearing prematurely like this. I highly doubt this would cause a leak though.
    10. #8
      Junior Member ButchIVIX's Avatar
      Aug 2017
      Florida
      Holy crap! That shouldn't deteriorate within 4 years! My 1st gen XC90 didn't need that in the 12 years I owned it. Definitely a warranty issue or at least ask for goodwill repair, unless of course, it was damaged by a foreign object.
      2020 XC90 T6 Inscription - Luxury, Advanced, & Protection Packages; Park Assist Pilot; 21" 8-Multi Spoke Alloy Wheels
      2008 XC90 3.2L FWD - Loaded, bulletproof, thank you for 12 years of flawless service! (Sold )
      2008 XC90 3.2L FWD - Lemon. Dealer buyback at 700 miles.
    11. #9
      Mar 2018
      DeKalb, Illinois
      Labor-$ 385.00
      Parts-$ 91.91
      Tax-$9.19
      Total-$ 486.13
      This is the estimate I received from a Volvo dealer near me. Not sure if VCNA can do something here under goodwill as I never placed anything on the roof and not sure how this happened.
      Sent from my SM-G781U using Tapatalk
    12. #10
      Member
      Aug 2017
      United States
      I probably wouldn't use my goodwill chance on something under $500, but it's your call.
    13. #11
      Sep 2019
      I happened to open my sunroof today because the weather was so nice. I noticed that only the front panel slide back, I somehow remember that both panels move, but after working from home for exactly seven months today, I am not sure about that at all - I looked at the space behind the second panel, but it was very obvious either way. Can anyone confirm?
    14. #12
      Sep 2019
      OK, just found the answer myself, looks like that's the way it is.
    15. #13
      Mar 2018
      DeKalb, Illinois
      Quote Originally Posted by Tech View Post
      As using it once may hurt the chance of using it for anything bigger again in the future like engine related?
    16. #14
      Member
      Aug 2017
      United States
      I don't have proof, but from what I've seen I believe previous goodwill is a consideration when evaluating goodwill.
    17. #15
      Jul 2015
      Hungary
      I had the same problem, but it was marten, not rubber wearing. Fortunately no leak.
    18. Remove Advertisements
    Similar Threads
    1. Rubber around Volume knob peeling off.
      By Skilla85 in forum S40 & V50 (2005-2012)
      Last Post: 06-06-2010, 05:12 PM
    2. Clear-Coat Peeling off of rear bumber
      By Bizon in forum R Forum (2004-2007)
      Last Post: 05-19-2010, 10:42 AM
    3. Rubber stripping on inside of windows peeling
      By WhiteS40TGirl in forum S40 & V50 (2005-2012)
      Last Post: 12-30-2005, 10:27 AM
    4. Mysterious black rubber piece fell off
      By volvoNB in forum S40 & V50 (2005-2012)
      Last Post: 03-11-2005, 09:20 PM
    5. Help, my trims are peeling off!
      By andreasschwerte in forum 850 (1993-1997)
      Last Post: 08-07-2004, 03:50 PM
