Drawtite Hitch for 2018 XC90 - Anyone have this on their Volvo?
    Results 1 to 20 of 20
      Jul 2017
      Long Island, NY
      Hi All,
      We are installing a hitch on our 2018 XC90. The Drawtite is much cheaper than the Stealth Hitch. I can get past the aesthetics of the Drawtite, but we are concerned that the Drawtite sticks out enough that we will be banging our shins into it while loading groceries, etc. into the hatch.
      Does anyone have the Drawtite on their XC90 and if so, is our concern warranted?
      Thanks!
      Junior Member Ultrarunner511's Avatar
      Jul 2017
      Arizona
      Quote Originally Posted by rsc92 View Post
      Hi All,
      Thanks!
      We have the Drawtite on the 2017 XC90 since 2017. Never had an issue. Between loading and unloading groceries, camping, etc, it's never been in the way and we have never hit our shins on it. I'll post a picture of a side view for reference.
      Sent from my SM-G975U using Tapatalk
      Jul 2017
      Long Island, NY
      Quote Originally Posted by Ultrarunner511 View Post
      Thanks very much. Look forward to the photo. All pictures we have seen make it look like the receiver hitch extends far enough to be an issue.
      SwedeSpeed.com
      Jul 2017
      Arizona
      At some angles it looks like it's protruding, but it doesn't extend past the bumper.
    7. #5
      Jul 2017
      Long Island, NY
      Thanks! Very helpful. I’m sending you a PM.
    8. #6
      Oct 2019
      I have that exact same hitch installed on my 2016 XC90 T6. U-Haul did a great job putting it on and it looks great, just like the prior post w/pictures. Never bumped into it once.
      For wiring I have it stored in the under floor compartment and just pull it to use when needed so no parts to worry about rusting out when it's externally installed.
    9. #7
      Jul 2017
      Long Island, NY
      Quote Originally Posted by Metalsaturn View Post
      Thanks. Do you know what wiring brand/module you went with?
    10. #8
      Junior Member Grendel's Avatar
      Dec 2003
      Seattle
      I have the Drawtite and just had it fitted to my '20 T6 Inscription last week. I was going to do it myself but feared I'd break clips getting the bumper cover on and off, and the place where I had it fitted broke a few clips getting the bumper cover on and off . I got the factory harness and factory towing module as it provides anti-sway capability as well as providing trailer brake control. I have a bowrider boat without trailer brakes but might occasionally tow my Miata. The module needs to be coded to the car and I'm having that done Monday, it will likely be 1-1.5 hours of labor. Haven't run into the thing loading/unloading anything.
    11. #9
      Member Gary-16-Xc90's Avatar
      May 2015
      Twin Cities, MN
      IMO, the Volvo OEM wiring harness and Volvo towing software are essential for towing. These components allow for an integrated system - tying into Sensus (including rear camera), anti-sway and braking as mentioned above and leveling (if you have air suspension).
      FWIW, although I have the InvisiHitch 2.0, I had the dealer install the tow bar, it, the Volvo OEM wiring harness which I purchased through the dealer and software.
      When it comes to wiring and software, I want the dealer doing it so there is no question or issue with the electrical systems or computer functionalities.
      2016 XC90 T8 Inscription | US 10/2015 Build| Crystal White | Blonde | Blonde | B&W | Air | HUD | Convenience Vision Climate | PAII + Mitigation Upgrades | Xpel + Gtechniq Ceramic | 3M Crystalline 50% Tint, 97% UV Rejection, 60% Solar Heat Rejection | 20" A/S & 22" Summer | Tow | Last TSU installed 10 Sept. 2020 | 47K miles | MPG 31.8 Lifetime including transcontinental trips, regional trips and towing
    12. #10
      Jun 2018
      Quote Originally Posted by Gary-16-Xc90 View Post
      All about cost reward. I don’t plan on towing often. Maybe 1x a year if that. Hard to justify that extra cost va $75 harness.
      If I was towing a boat every weekend I would agree with Gary.
      Sid
      2019 Volvo XC90 T6 OSD
      2007 Porsche 911 Turbo
      2004 Dodge Viper SRT-10
      2012 Ducati Diavel
    13. #11
      Dec 2003
      Seattle
      Good points. I have the air suspension and that is another plus with the factory module. I should've had the dealer do everything as the place I used charged me a fair bit more than they quoted initially.
    14. #12
      Nov 2016
      I have the stealth hitch (a variation of invisible hitch). Initially only bought the rack style (not for towing) and after one year added the tow package and OEM harness/module from Volvo (also sold by stealth hitch) and had the dealer program the car. Agreed to people above, the software update is a must, I was very impressed to see the air suspension was self leveling when I parked on a sloped road with a big uhaul trailer. As for installation, I installed everything myself, the only cost was software update for $150 at dealership. The whole installation process was not hard as it seemed to be, YouTube video is available and instructions are well written.
    15. #13
      Member drmanny3's Avatar
      Jun 2018
      Santa Barbara, CA, USA
      I installed the Drawtite hitch and initially used a plug and play harness ($70) to hook up the rear tail lights. It was an easy install. I later replaced with the OEM harness and module and had the unit activated via VIDA. If you are not towing much then go with the Drawtite unit, and get yourself a plug and play rear taillight harness. https://www.etrailer.com/t1-2017_Vol...tm?&Redirect=8 is a good place to start. YouTube has a number of videos that you can follow. One removes the entire bumper, one removes the lower half. It will help to have one extra person when you remove the bumper. Make sure you get the lock for stabilizing the bike rack to minimize rocking.
      2017 Acura NSX Nouvelle Blue Pearl, Ceramic Brakes
      2017 XC90 T8 Inscription Onyx Black, BW, Leather Dash, Convenience, Vision, Luxury, Air Suspension, Climate, 21" Wheels
      2017 Bolt Premium Red
      2015 Kia Soul EV+
      2015 Toyota Highlander Hybrid
      2014 Toyota Rav4EV (one of 2600 compliance California only cars)
      2011 Nissan Leaf
      2005, 2006 Prius
      5 Corvettes, Porsche 911, Fairlady, 3 Z Cars, Countless VWs from Bugs to Vans, to Fastbacks, and Squareback
      Buicks, Chevys, Fords,
    16. #14
      Jul 2017
      Long Island, NY
      Thanks for all of the input.
      For anyone that installed the Volvo module and wiring, did you route the connector to the outside and attach to hitch? If so how did you secure it to the hitch? If not do you just leave the excess wire in well with spare tire when not in use?
      Thanks
    17. #15
      Oct 2017
      Had Draw-Tite hitch installed at Uhaul last week - took about an hour, $150 for the hitch and $80 labor. Can confirm no protrusion whatsoever, although in some pics it does look like it could've been an issue.
      Installed this basic $40 harness on my own last night. Does the job for signaling and braking, but doesn't do fancier features, if that's a must for you. Getting to passenger side light disconnect is a major pain. Glad I didn't do it at Uhaul, I am sure those guys would've ripped some plastic trim if not being careful.
      Also provided instructions for T5-T6 models appear to not fully apply to T8, with potentially less panels to disassemble in T8 I think.
      https://www.etrailer.com/Custom-Fit-...leID=201737949
      Poverty-spec 2016 XC90 T8 Momentum
      Zero options, $52K out the door brand new
    18. #16
      Feb 2017
      Anyone have experience comparing the Draw-Tite hitch and Stealth Hitch? The Stealth hitch (with tow package) is nearly $900 more than the Draw-Tite.
    19. #17
      Jun 2018
      Thanks
      I opted to leave the connector inside the car under the rear floor cover. So when I need to connect to a trailer I just open the floor cover and then connect the relatively thin trailer connector. The hatch closes without any problems on top of the wiring. This way I do not keep the connector exposed to the elements.
      2015 Kia Soul EV+
      2011 Nissan Leaf
      2005, 2006 Prius
    20. #18
      Jun 2020
      Austin, TX
      Quote Originally Posted by Vetallist View Post
      Did you order the Draw-Tite hitch from UHAUL? I ordered and paid for it in July but Uhaul told me "We have been experiencing a national hitch shortage, which has led to installation delays. " So I still don't see my hitch coming.
    21. #19
      Oct 2017
      Quote Originally Posted by winder View Post
      yep, straight up Uhaul online order and an appointment for install was about 10 days later. You could certainly get the hitch yourself and ask your local Uhaul location (or two) if they'll put it on at their install rate.
      I installed a hitch on my previous ride myself (Hyundai Santa Fe), which was a breeze, but this one I'll gladly pay triple what they are charging!
    22. #20
      Jun 2020
      Austin, TX
      sent another inquiry email today to Uhaul. Finally they have it and set up appointment for installation.
    23. Remove Advertisements
    Similar Threads
    1. Installed Drawtite towing hitch
      By FusionRedXC60 in forum XC60 (SPA: 2018- )
      Last Post: 07-12-2020, 07:19 AM
    2. How to Install DrawTite (or Curt) Hitch on 2015 XC60
      By TonyJag in forum XC60 (2010 - 2017)
      Last Post: 09-23-2015, 07:25 PM
    3. Drawtite Tow Hitch
      By dphilips in forum FWD & AWD Parts For Sale
      Last Post: 08-12-2010, 01:10 PM
    4. Replies: 1
      Last Post: 08-28-2004, 12:02 PM
    5. Replies: 0
      Last Post: 10-18-2003, 11:49 AM
