Anyone else having issues with early fuel cut-off at Costco Gas?
    Results 1 to 12 of 12
      Aug 2019
      Lately I've been struggling with our MY18 XC90 cutting off the fuel pump before full (sometimes WAY before, even at 50% full) when refueling at Costco Gas locations. We don't fuel often at non-Costco locations, but the few times we have gone to e.g. Shell we haven't had any issues. Volvo Orange County couldn't replicate the issue either when they looked into it, so I wanted to check in here to see if others have encountered the same issue. Have anyone else had this happen with their XC90?
      Mar 2019
      Happened to me. Not only at Costco, also at Shell and Chevron. In some cases it can be "fixed" by lifting end of handle so there will be better seal/contact with tank opening.
      2019 XC90 T8 Inscription, Denim Blue, ~everything sans B&W
      Jul 2016
      Quote Originally Posted by torstein View Post
      Yes this happens to me too!! Volvo had no fix for it. It's so annoying to get back in your car and realize it's not even full.
      Sent from my SM-N975U using Tapatalk
      SwedeSpeed.com
      Mar 2018
      DeKalb, Illinois
      Strange, I didn't encounter this issue yet and I fill at Costco regularly
      Sent from my SM-G781U using Tapatalk
      Our first Volvo - Optimus Prime - 2016 XC90 T6 Momentum Onyx Black, HUD, Momentum+, Convenience, Vision, Climate, Pilot Assist II + Mitigation Upgrades + Jan 2020 Update
      My Fuel Log for real life Optimus Prime fuel efficiency - http://www.fuelly.com/car/volvo/xc90...wdarygm/910536
    7. #5
      Jul 2016
      Quote Originally Posted by chowdarygm View Post
      For me it happens about one in 4 times
    8. #6
      Member Gary-16-Xc90's Avatar
      May 2015
      Twin Cities, MN
      I have had zero issues at Costco in MN, but I have had issues at BP and some other stations.
      All the best from Minnesota USA,
      A fine MY16 XC90 T8
      2016 XC90 T8 Inscription | US 10/2015 Build| Crystal White | Blonde | Blonde | B&W | Air | HUD | Convenience Vision Climate | PAII + Mitigation Upgrades | Xpel + Gtechniq Ceramic | 3M Crystalline 50% Tint, 97% UV Rejection, 60% Solar Heat Rejection | 20" A/S & 22" Summer | Tow | Last TSU installed 10 Sept. 2020 | 47K miles | MPG 31.8 Lifetime including transcontinental trips, regional trips and towing
    9. #7
      Dec 2012
      Pump cutoff is managed by the pump/pump handle, not the car.
      Probably new designs to limit environmental
      Impact from evaporating gas.
    10. #8
      Member inteller's Avatar
      Aug 2009
      Tulsa, OK
      Quote Originally Posted by TheNip73 View Post
      Yes this is what it is.
      Sent from my SM-G973U1 using Tapatalk
      2016 Bright Silver Metallic XC90 T8 Inscription, everything
      2015.5 Rebel Blue S60 Polestar 18/40
      2006 Passion Red S60R
      Packages: Premium, Climate Options: Sport Appearance Package, 18" Pegs, 6Spd Geartronic, Navigation
      Accessories: Sunglasses holder, Sirius Radio, Volvo Digital Jukebox Mods:SS DEM Mod
      "Just say no to LV VIN codes"
    11. #9
      Member satrya's Avatar
      Jan 2018
      Fremont, north california
      I found that in stations where the pump tend to stop early on my SPA (but not my other vehicles), I can make it fill up completely if I experiment with the angle of the gas nozzle handle. My guess is it has to do with the pressure distribution around the perimeter of the seal due to the orientation of the gas nozzle, which may affect how gas hose weight is being exerted onto the seal perimeter.
      At the extreme, if I rotate the gas nozzle so that the trigger handle is about 45 degrees from vertical, it is almost impossible to keep a good seal and the pump easily stops gas delivery. Some gas stations seem to be ok with the nozzle handle "almost" vertical but not exactly vertical, and others seem to be more sensitive to this. When the nozzle is being pulled from the pump into your vehicle's fill port, the hose and support mechanism may make the gas nozzle rotate more than is necessary to ensure proper seal.
      Denim Blue 2018 xc90 T6 Momentum+
    12. #10
      Feb 2016
      It might be the pump’s sensor tube is clogged. That’s how a gas pump knows when to stop:
      https://youtu.be/TFKOD3KRkZs
    13. #11
      Junior Member Ultrarunner511's Avatar
      Jul 2017
      Arizona
      We use Costco almost exclusively since we got our 2017 XC90. Never had this issue. Never had the issue on the 2020 or the 2021.
      Sent from my SM-G975U using Tapatalk
    14. #12
      Jul 2016
      I don't have the issue in any of my other cars though, just the Volvo.
    15. Remove Advertisements
    Similar Threads
    1. Anyone else having issues with capless gas tank?
      By dbetterton in forum XC40 (CMA 2019- )
      Last Post: 03-01-2019, 10:58 AM
    2. Love it but anyone else having really weird issues?
      By christiansin in forum XC90 (SPA: 2016 - )
      Last Post: 08-25-2017, 05:17 PM
    3. Replies: 22
      Last Post: 02-10-2016, 02:07 PM
    4. Frozen brakes, cold Haldex, anyone else having these issues
      By rein_00 in forum R Forum (2004-2007)
      Last Post: 11-25-2015, 10:11 PM
    5. anybody else having issues with swedespeed website???
      By RadioZero in forum C70 (2006-2013)
      Last Post: 09-12-2013, 10:50 AM
