2004 s60 throttle body! Help!
    Results 1 to 5 of 5
      Sep 2018
      Hello all
      I know there has been 1000s of posts probably about this but im super confused because Ive seen different answers to this question
      I have a 2004 Volvo S60 2.4 Automatic transmission VIN 61 and the idle is surging up and down so Im looking at the throttle body. Ive cleaned it, The MAF sensor as well. It seems to do it only once its warmed up and drives fine at normal driving speed ( 40-60 MPH)
      The big question is does a replacement throttle body need programming by the dealer? I have heard yes and no. I looked at mine on the vehicle and am not able to obtain any part numbers for what I have now. I look on auto parts websites and type in the vehicle info and I get different part numbers of various prices and a multitude of brands. I know oem is the way to go. I also know that this is a 2004 and Im only going to spend so much.
      Can somebody please steer me in the right direction? Could there be something else to try like 02 sensors? I have no CEL at this time too if that helps.
      I contacted Xemodex in Canada too and they dont support that make and model at this time.
      Nov 2018
      Several years ago I had a Toyota with similar symptoms. When the engine was hot, and I stopped to refuel, I had to open the hood and let the engine cool so I could get started and be on my way. It turned out to be the mass airflow sensor(MAF), which was eventually replaced. I think I drove it several thousand miles with the problem, which led to some interesting situations, like when I would park the car to do some shopping, and open the hood to let the engine cool down.
      Quote Originally Posted by briknope View Post
      Hello all
      I put in the 70mm Porsche throttle body and had some surging and erratic throttle responses but Hilton tuned it to perfection....cheeky I know.
      SwedeSpeed.com
      Member
      Jul 2015
      Charlotte, NC
      I'm fairly certain the Bosch ETBs require programming. Do you have any codes? That's the first place to look for diagnosing an issue like this. Time to open up VIDA!
      I know on some P2s, the wiring is known to deteriorate on the harness connecting to the throttle body. May be worth a look just to be sure.
      2000 V70R Venetian Red/Charcoal M56 Swapped 200k
      2003 S60 2.4T Silver/Black 118k
      1991 944 Turbo B230FT/AW70 175k
      1992 245 crusty roller/driveway ornament/eventual V8 swap 249k
      2007 XC90 V8 AWD Sport Titanium Grey/Black 174k
      1999 BMW 528iT Alpine White/Sand Beige 246k
      2001 Mercury Mountaineer 5.0 junk hauler 211k
      2001 Miata with the wrong transmission 134k
      Sold-
      1998 V70 GLT Black/Beige 193k
      1998 S90- Silver/Gray 207k
      1995 850 GLT Tropic Green... crushed
      1993 944 B230F/AW71L 221k
      2000 S70 GLT Silver/Taupe 253k
      2001 S60 2.4T Black/Black 230k
      1988 744 Turbo M46 Beige Metallic/Beige 188k
      Need used parts? PM me!
    7. #5
      Member
      Apr 2013
      Toronto, Canada
      I replaced the Bosch Throttle body on my 04 S60 with a xemodex a few year back. It did not require reprogramming but did require me too run an “adaptation” in vida to get it working.
      2010 V70 3.2 125,000miles
      2002 V70XC, 175,000 miles
      2004 S60 2.5T, 160,000 miles
    8. Remove Advertisements
    Similar Threads
    1. 850 & 98 x70 NA Throttle Body w/960 Throttle Blade
      By ScottishBrick in forum FWD & AWD Parts For Sale
      Last Post: 03-28-2018, 06:33 AM
    2. throttle position sensor/throttle body question.....
      By dlk1 in forum S40 & V50 (2005-2012)
      Last Post: 09-25-2017, 11:31 AM
    3. Replies: 6
      Last Post: 10-21-2016, 09:49 PM
    4. ipd throttle inlet tube with phenolic throttle body spacer
      By doru in forum R Forum (2004-2007)
      Last Post: 12-01-2015, 02:15 PM
    5. NA 850 Throttle Body w/S80 Throttle Plate w/ Gaskets $100 shipped
      By XJFLEXER in forum FWD & AWD Parts For Sale
      Last Post: 08-12-2014, 08:46 AM
