Oil pressure light randomly coming on, oil level fine - Page 2
    Page 2 of 3 FirstFirst 1 2 3 LastLast
    Results 36 to 70 of 93
    1. #36
      Junior Member Facusan's Avatar
      Nov 2014
      Houston, TX
      Sorry for being a little bit rude, but I think itís not worth risking a good running car until you figure out the cause of this problem.
      Member evy0311's Avatar
      Aug 2016
      Ohio, USA
      Quote Originally Posted by Facusan View Post
      Yeah I agree. I donít have to drive the car for the next week or so so itís going to sit but when Iím back I plan on looking further into this. Itís just hard because the light is so intermittent that I canít exactly narrow down the cause of it without dropping the pan.
      2006 S40 2.4i FWD
    4. #38
      Nov 2014
      Houston, TX
      Quote Originally Posted by evy0311 View Post
      Well, you actually can do that. Get an oil pressure gauge. Harbor freight sells one for $30
      IMHO Spending $30 beats having to drop the oil pan. Any day.
      SwedeSpeed.com
      Aug 2016
      Ohio, USA
      I assume this would leave the light on on the dash correct?
      And then also I assume thereís no way for me to drive with a gauge on?
      2006 S40 2.4i FWD
    7. #40
      Nov 2014
      Houston, TX
      If you follow the exact VIDA procedure, yes.
      If you add a T fitting then no.
      I would try the VIDA procedure first. Youíll need somebody on the car to move the accelerator pedal. And since youíre already there get a new oil pressure sensor.
      If the oil pressure on the gauge is normal, and you still have the intermittent light, that could be an electrical problem.
      If you want to drive the car, i guess you would need an extension hose for the gauge.
      Or a very brave friend:
    8. #41
      Aug 2016
      Ohio, USA
      Got it.
      Also- that picture?!? If you guys see an article on the news that looks just like that... itís probably me [emoji51][emoji23]
      2006 S40 2.4i FWD
    9. #42
      Global Moderator tmtalpey's Avatar
      Jun 2004
      Eastern MA
      I would not suggest a T- fitting, it can potentially change the reading, and it should be temporary!
      If you insist, then put the gauge on a straight through leg, and the sensor on the 90. Don't run any extra tubing.
      2005 V50 T5 AWD 6MT w/Heico tune, Heico exhaust, Bell intercooler, IPD TCV, Viva Forge CBV, Elevate rear swaybar and torque mount, Snabb shift kit, etc.
      2016 XC60 T6 AWD
      1956 PV444 complete, running
      1956 PV444 very original, very rough
    10. #43
      Aug 2016
      Ohio, USA
      Quote Originally Posted by tmtalpey View Post
      Question, if nobody here knows I can try to find it in VIDA, But what would a ďnormalĒ oil pressure reading be on the 2.4i motor? Again I can try to dig it up in Vida if nobody knows. I know itís above 7psi for the light to not be on (per a post in this thread).
      2006 S40 2.4i FWD
    11. #44
      Nov 2014
      Houston, TX
      Air in the fitting/lines affecting the reading??
      Good point on that!
    12. #45
      Jun 2004
      Eastern MA
      Air, debris, you name it. It might be accurate, but you don't want guessing.
      I'm not sure if there's a factory spec, but IMO on a Volvo engine (exceptionally well-made) you want to see 20+ psi at idle and double that at higher rpm. If you see 7psi on a cold engine, you are in trouble. Heck, if you see it on a hot engine, you have an issue.
      2016 XC60 T6 AWD
    13. #46
      Nov 2018
      I am not sure why you found sludge in your oil pan. If there was sludge in the bottom of the pan, there could be sludge somewhere else in the engine, and that might be the cause of intermittent low oil pressure warning. My 2005 S60 gets an oil change at 3000 mile intervals, and I have no reason to think that there is sludge anywhere in the engine. However, the 10,000 mile oil change interval does have an environmental benefit, since there is less waste oil generated. It also reduces maintenance cost. If my car had the low oil pressure warning, and yet the dipstick indicated the oil level is OK, I would suspect some problem with the oil pickup mechanism.
    14. #47
      Aug 2016
      Ohio, USA
      Quote Originally Posted by Eric T Johnson View Post
      I believe the PO might have gone longer without oil changes and without changing the PCV, so there was some crud buildup in the tubes where PCV gasses flow from the pan. Thatís all the sludge was, and I cleared it out and it looks good now. I now do oil changes between 5-7k miles and use full synthetic. The oil pickup mechanism and tube was completely fine when I checked it.
      2006 S40 2.4i FWD
    15. #48
      Sep 2015
      Also to add, two months ago I had dropped my oil pan and cleared out all the sludge around the pickup tube, etc, and replaced all seals and gaskets relating to the oil pan/oil cooler. So I doubt the pickup tube is clogged, as I also changed the oil then as well.
      Was there something happening that caused you drop the oil pan and clean the sludge?
    16. #49
      Aug 2016
      Ohio, USA
      Quote Originally Posted by icepickjazz View Post
      Iíve had my check engine light on since I bought my car. The code is related to the MAF. Iíve changed almost every sensor on the motor but sometimes when coming to a stop it hunts for idle. Per the recommendation of moosetech (for those who know him) he suggested I check the PCV passageways that lead to the oil pan and clear them. They were gunked up so I did clear them, and there was no change relating to the MAF code.
      2006 S40 2.4i FWD
    17. #50
      Nov 2014
      Houston, TX
      I found the oil pressure specifications on VIDA, it seems this applies only for 2.4 and 2.4i engines (B5244S4 , B5244S5 & B5244S7)
      Oil pressure (min.)
      13.3 r/s (800 rpm) ........0.10 MpaĻ (14.5 psi)
      14.2 r/s (850 rpm) ........0.10 MpaĻ (14.5 psi)
      66.7 r/s (4000 rpm) .......0.35 MpaĻ (50.8 psi)
      Maximum oil pressure (the relief valve opens) ........0.48 MpaĻ (69.6 psi)
      ĻThe oil pressure given is for an oil temperature of 100 įC, which is reached after 10Ė15 minutes driving.
    18. #51
      Aug 2016
      Ohio, USA
      Awesome, thanks very much. Iíll try to get out to harbor freight this weekend and pickup the gauge, damn airbox is gonna be a PITA to remove so maybe Iíll just build a custom air intake while Iím at it so I donít have to put the damn thing back in. Thank you all for all the help, Iíll keep you posted on my findings.
      2006 S40 2.4i FWD
    19. #52
      Nov 2014
      Houston, TX
      You may not need to remove the air box, you can access the sensor from under the car
    20. #53
      Do you know if the prior owner ran conventional and never let the car cool off before shutting down?
      Originally these cars were spec'd to run conventional...
      1996 HD Electra Glide - Big Bertha - 10:1 Wisecos; EV13 Cam: Ultima Digital Ignition; Buell Head Conversion; E85 Carb Tuned;
    21. #54
      Jun 2004
      Eastern MA
      This.
      2016 XC60 T6 AWD
    22. #55
      Aug 2016
      Ohio, USA
      Quote Originally Posted by avenger09123 View Post
      I can check my maintenance records I got from them, I believe they were running whatever was recommended in the manual/by Volvo as a lot of the original maintenance was done by a Volvo dealership.
      Wouldnt full synthetic be better at such a high mileage?
      2006 S40 2.4i FWD
    23. #56
      Aug 2016
      Ohio, USA
      Getting under the car will be hard for me currently as Iím away at school and donít have any ramps/good jack etc. Iíve been looking at buying a set of rhino ramps though to keep at my apartment in case I ever need to do basic work like oil changes while Iím up here.
      Iíll try to see what I can do because if I can avoid removing the airbox Iím all for it, itís a pita to get out. Iíll also go ahead and order a new oil switch just to replace while Iím under there for good measure, especially if the pressures do seem normal.
      2006 S40 2.4i FWD
    24. #57
      Nov 2014
      Houston, TX
      You can get a pair of 2-ton jack stands for ~$25 and a 2-ton trolley jack for -$30 at walmart.
      Thatís what Iíve been using for the last 3 years.
      The jack stands work perfect and gave me no problems at all.
      The trolley jack, well..... It leaks oil and after 2.5 years it wasnít raising the car enough to fit the jackstand (it had very low oil), I refilled it with rotella 10w-40 heavy duty diesel oil and now works like a charm. It still leaks a little bit of oil though.
    25. #58
      Aug 2016
      Ohio, USA
      The biggest problem is storing them. Rhino ramps are really light and easy to carry into my apartment whereas a trolley jack well... thatís another story! Next year though Iíll have more of a proper way to store these types of things. My apartment is just small and I have no garage etc.
      2006 S40 2.4i FWD
    26. #59
      Nov 2014
      Houston, TX
      Iím in the same situation.
      And what you see there are 4 jackstands 1 trolley jack, 4 hockey pucks and 2 wheel chocks. They all fit in a small archive cabinet.
    27. #60
      Aug 2016
      Ohio, USA
      Okay maybe I can do it.... lol. Being in college sucks as a car guy because I have a lot of time to work on my car, but no good place to do it unless I want to drive 2 hours back to my parents... the struggles!
      If I do end up taking out the airbox, I assume itís a straight shot to the oil pressure sensor? If I remember correctly last time we changed it (4-5 years back) we went from the bottom, so I assume itís right behind it?
      2006 S40 2.4i FWD
    28. #61
      Nov 2014
      Houston, TX
      Not really, it is on the passenger side of where the dipstick tube connects to the block, a little bit above the oil pan
    29. #62
      Jun 2004
      Eastern MA
      Yeah, removing the airbox really doesn't help much. I marked up Facusan's photo
      2016 XC60 T6 AWD
    30. #63
      Aug 2016
      Ohio, USA
      I see, so you do need to go from under the car. Well Iíll look into getting some rhino ramps or something so I can get under there and go at it. Any reason to get the OEM sensor over something aftermarket like iPD? Will OEM last longer or are they all about the same?
      2006 S40 2.4i FWD
    31. #64
      Jun 2004
      Eastern MA
      You want the OEM part for this, but I bet that's exactly what iPD sells.
      Test first and maybe save your money.
      2016 XC60 T6 AWD
    32. #65
      Sep 2015
      I went through a similar issue with a Toyota 1MZFE engine which is a known sludger. I replaced the valve stem seals and clean a bunch of carbon/sludge related to pvc. Intermittent oil pressure light afterwards. Knocking the sludge/carbon loose can cause a lot of issues. I replaced the Oil Pressure sensor w/o testing the oil pressure, which didn't resolve the issue. Then, i purchased oil pressure gauge and found oil pressure was not adequate. if you purchase the pressure gauge from HF. Need to run the engine for 15-20 minutes and recorded the oil pressure ever 2 minutes or so. Also need to rev the engine around 3,000 RPM and record the pressure. You need to understand pressure at both idle and under type of load. The pressure will drop as theh oil becomes warmer so it is important to monitoir pressure for a longer period of time.
      After replacing the sensor and no change, i did some additional investigation. Found both the oil filter was clogged, oil pick up tube clogged. Easy to check your filter and replace. You may need to drop the oil pan again, clean the pickup tube and double check the o-rings.
    33. #66
      Aug 2016
      Ohio, USA
      Could it be possible that in your case, and potentially in mine, that the oil sludge you knocked loose allowed more sludge to break free and clog the filter/pickup tube? Iím gonna check my filter as well just to make sure it didnít get clogged up wuick. Thanks for the info though!
      2006 S40 2.4i FWD
    34. #67
      Aug 2016
      Ohio, USA
      Going to pop the oil filter out this week and check out if there is a lot of sludge built up or not. I have a feeling that me clearing the PCV and other oil passages might have allowed some sludge to break free and that it is potentially clogging the filter housing and not letting oil go back down into the pan to be picked up. Also need to try and source a filter but nobody has European made ones here locally. Probably not a huge deal, Iíd just prefer something like Mann.
      2006 S40 2.4i FWD
    35. #68
      Nov 2014
      Houston, TX
      Iíve used a few Mexican-made MANN filters and theyíre as good as the German-made.
      I used to buy the filters at Advance auto parts at ~$7
      I also checked out the Purolator branded filters, which were more expensive (~$13), and inside the box found a MANN branded filter.
    36. #69
      Aug 2016
      Ohio, USA
      Good to note- I figured most filters were made by probably a select few companies, Mann being one of them, and then just rebranded.
      2006 S40 2.4i FWD
    37. #70
      Nov 2014
      Houston, TX
      Yeah, that happens almost with everything in these days.
      BTW, The purolator it wasnít even rebranded. It had MANN and HU719/8X written on it, the only difference was the box.
    38. Remove Advertisements
    Similar Threads
    1. 2.0D oil pressure light coming on
      By mnvizb in forum S40 & V50 (2005-2012)
      Last Post: 10-11-2017, 11:24 AM
    2. Replies: 2
      Last Post: 01-12-2013, 06:30 AM
    3. Replies: 12
      Last Post: 12-14-2012, 09:13 PM
    4. Backup Lights: Bulbs fine, fuse fine, no lights.
      By vizwiz in forum R Forum (2004-2007)
      Last Post: 12-01-2012, 06:18 PM
    5. Low oil level warning, but oil level is OK. Your thoughts?
      By qwkbrk in forum R Forum (2004-2007)
      Last Post: 01-05-2011, 04:08 PM
